Author Topic: Flight stick  (Read 8865 times)
Dana
Flight stick
« on: June 25, 2022, 11:23:20 AM »
As i am not happy with the software version 6 i want to ask if it is possible to use green flight stick with software 3.13 or 4.03 ? For personal use to display flights on my laptop.
Thank you :)
Re: Flight stick
« Reply #1 on: June 25, 2022, 01:38:34 PM »
Yes it is, no issues with it you will only need to use the Flightstick driver
Dana
Re: Flight stick
« Reply #2 on: June 25, 2022, 04:31:45 PM »
Unfortunately it says Hardware Not Connected. I try with flight stick drivers....:(
Re: Flight stick
« Reply #3 on: June 25, 2022, 05:40:44 PM »
Try using Zadig drivers
Dana
Re: Flight stick
« Reply #4 on: June 25, 2022, 05:50:41 PM »
i used Zadig it works but with V6. software.
on V3.13 OR 4.04 it say Hardware Not Connected....
Re: Flight stick
« Reply #5 on: June 25, 2022, 05:57:33 PM »
Well I can only presume the answer is no then
What is it you dont like on V6.01
Dana
Re: Flight stick
« Reply #6 on: June 25, 2022, 06:11:59 PM »
In V6 I dont like: screen refresh rate if i set it 1sec the parh vector is moving in other direction than the plane target.tineout flight if i set it less then 5 sec some flights apear as timeout flights. and some other problems. Who created the software did not pay attention on all details. The old version 3.13 and 4,03 was more accurate, the only problem there was duplicated flights. all other details was accurate. Thank you Alan :)
Re: Flight stick
« Reply #7 on: June 25, 2022, 06:36:24 PM »
I remember now from when it came out origionally
