MLAT not working after Raspi update and selecting yes instead of no for rbfeeder
Started by DZpower, July 16, 2022, 01:41:46 PM
DZpower
My MLAT does not work since i did an update on my Raspi
i did re-install RBFEEDER via CLI  but still no luck with getting MLAT back
DZpower
i can provide logs upon request and would appreciate any help or suggestion
(1) First run this command
sudo apt update
(2) Next issue following commands and post their output
uname -a
lsb_release -a
apt-cache policy rbfeeder
apt-cache policy mlat-client
apt-cache policy python3
(3) Also post output of following command (replace key by xxxxxx when posting)
cat /etc/rbfeeder.ini
DZpower
when i run the sudo apt  update it does show that it's all up to date
When i run the sudo nano command
[client]
network_mode=true
key=xxxxxxxx
sn=EXTRPI026653
lat=42.381765999999999
lon=-71.097617
alt=41
[network]
mode=beast
external_port=30005
external_host=127.0.0.1
[mlat]
autostart_mlat=true
mlat_cmd=/usr/bin/python3.7 /usr/bin/mlat-client
[dump978]
dump978_enabled=false
DZpower
 Raspbian GNU/Linux 10 (buster)
Release:        10
Codename:       buster
rbfeeder:
  Installed: 1:1.0.8+deb10
  Candidate: 1:1.0.8+deb10
  Version table:
*** 1:1.0.8+deb10 500
mlat-client:
  Installed: 0.2.11
  Candidate: 0.2.11
  Version table:
*** 0.2.11 500
DZpower
it does not allow me to copy and past result of  the rbfeeder  this post bock it as spam or some filters
i see a a lot of errors
PermissionError: [Errno 13] Permission denied: '/run/ml
  open(pidfile, 'w').write(pid)
usr/bin/mlat-client", line 108, in <module>
DZpower
i see some errors
"PermissionError: [Errno 13] Permission denied: '/run/mlat-client.pid"
File "/usr/bin/mlat-client", line 108, in <module>
PermissionError: [Errno 13] Permission denied: '/run/mlat-client.pid'
Traceback (most recent call last):
File "/usr/bin/mlat-client", line 108, in <module>"
DZpower
Quote from: abcd567 on July 16, 2022, 02:21:24 PM
sudo apt update
uname -a
lsb_release -a
.please check your private message
Seems mlat-client installed from RB24 site (using command sudo apt install mlat-client) has some defect. Better purge it, then build & install from source code
(1) First purge existing package
sudo apt purge mlat-client
(2) Install dependencies and tools required to build package from source-code
sudo apt update -y
sudo apt install -y git curl build-essential debhelper python-dev python3-dev
(3) Downloaded source code and build mlat-client's installation package.
cd
git clone https://github.com/mutability/mlat-client.git
cd mlat-client
sudo apt install -y dh-python
sudo dpkg-buildpackage -b -uc
(4) Install newly built package by following command
cd
sudo dpkg -i mlat-client_*.deb
DZpower
When in future any update/upgrade command is run, it will replace healthy mlat-client (which you have built yourself) by the defective mlat-client from RB24 repository.
To prevent this, put your mlat-client on hold by following command
sudo apt-mark hold  mlat-client
The responce to above command will be:
mlat-client set on hold..
abcd, have you advised Airnav  of their defective MLAT client?  If not are you aware of the defect and I can advise
Alan, no, I have not advised AirNav about the defective mlat client because:
(1) up till now only 2 cases have been reported in forum
(2) I cannot make out what is exactly the defecti, is it because of a corrupted files or because of some changes made by RB24 developers in the source code.
If you like you can inform support with links to the two lates threads  on this issue.
abcd
