Author Topic: automatically after 1 minute.  (Read 9287 times)
Erich
« on: August 06, 2022, 06:54:12 AM »
Hello in the forum!
After my RadarBox gave up after 17 years, a
AirNav Micro Stick installs but it is recognized and shows everything that is necessary
But it turns off automatically after 1 minute.
Zadig Dreiber 2.4 is inst. Also available in Device Manager as RTL28.28UHIDIR
Why does Airnav Micro turn itself off???
Anyone have this problem???
LG Eric
Re: automatically after 1 minute.
« Reply #1 on: August 06, 2022, 07:16:04 PM »
No reason why it should turn itself off, I use one myself and it is on all day.
Do you have power saving set up for your usb ports or similar, I would check that out
Erich
« Reply #2 on: August 08, 2022, 01:35:09 PM »
Hello Alen!
Alen I think I expressed myself wrong on AirNavMicro
After about 1-2 minutes the hardware is disconect, i.e. map and interface
Are then empty no display and below the green button changes to red.
Should I reinstall Radarbox or Micro Stick.
Or does it also recognize the micro stick with only the radar box???
LGErich
« Reply #3 on: August 08, 2022, 02:23:39 PM »
I would suggest that you reinstall Radarbox software, the fact that it works suggests that the driver is installed ok but reinstall the drivers again as well
  • CYYZ - Toronto
« Reply #4 on: August 08, 2022, 05:58:21 PM »
@Erich
You can easily check your Micro Stick using method described in this How-To:
Is My DVB-T RTL SDR Dongle Healthy?
Erich
« Reply #5 on: August 29, 2022, 07:26:51 AM »
Hello in support!
So my ADSB Stick AirNav is bad didn't work properly
Has always after 1-2 min. Disconnect on hardware as written
Switched. The purchase of a new AirNav Stick has the problem
Solved and everything is like it used to be with my black radar box.
LG Eric
« Reply #6 on: August 29, 2022, 10:04:31 AM »
Good to know
