Author Topic: Radarbox connected for 3 days, then disconnected AGAIN  (Read 20714 times)
Av8tor_from_Argentina
« on: August 07, 2022, 11:09:44 PM »
Good morning. I had an issue since my last reboot/reinstall of all flight trackers software installed in my Rpi.
I have working and feeding Flightradar24, Flightaware and Planefinder. All of them work perfectly, the only one who refuses to work is RadarBox24
Suddenly a week ago, I´ve received an email stating that My account is back online again.. CHecked and was true.. ONLY FOR 3 days.. today my RadarBox24 is down... and is really annoying because it wasn´t working, and as started to work by herself, stopped by herself...
Anyone knows or "suffered" the same glitch, ghost, whatever you name it ??
Regards from Argentina
« Last Edit: August 08, 2022, 12:13:02 AM by Av8tor_from_Argentina »
Re: Radarbox connected for 3 days, then disconnected AGAIN
« Reply #1 on: August 08, 2022, 12:18:38 PM »
I cannot copy/paste because forum system rejected due to spam suspect...
attached is the systemctl status rbfeeder output
Maybe someone knows whats going on... I have 3 other providers working perfectly.
  • CYYZ - Toronto
« Reply #2 on: August 08, 2022, 10:34:14 PM »
please run following command and post its output.
(replace key by xxxxxxxxxxx when posting)
sudo cat /etc/rbfeeder.ini
« Reply #3 on: August 09, 2022, 01:22:34 PM »
Good morning. Here you have...
Marco@raspberry:~ $ sudo cat /etc/rbfeeder.ini
[client]
network_mode=true
key=xxxxxxxxxxx
sn=EXTRPI027210
lat=-3x.xxxxx
lon=-5x.xxxxx
[network]
mode=beast
external_port=30005
external_host=127.0.0.1
[mlat]
autostart_mlat=true
[dump978]
#dump978_enabled=false
  • CYYZ - Toronto
« Reply #4 on: August 09, 2022, 09:21:38 PM »
Your rbfeeder config settings are OK..
Maybe some other files of rbfeeder got broken/corrupted during install. Try purging current install, then update, then make a fresh install
Code: [Select]
sudo apt purge rbfeeder
sudo apt update
sudo apt install rbfeeder
« Last Edit: August 09, 2022, 10:03:30 PM by abcd567 »
« Reply #5 on: August 10, 2022, 11:14:50 PM »
Thanks ABCD567, here you have the output from the installation...
It is attached because spam issue with the forum soft...
Something is not right at the end of the file...
  • CYYZ - Toronto
« Reply #6 on: August 11, 2022, 03:05:16 AM »
(1) Which model your Pi is?
(2) Which OS image did you write to microSD card?
Code: [Select]
Preparing to unpack .../rbfeeder_1%3a1.0.8+deb11_armhf.deb ...
Unpacking rbfeeder (1:1.0.8+deb11) ...
Setting up rbfeeder (1:1.0.8+deb11) ...
Checking if service is running and restart, if needed...
Failed to restart rbfeeder.service: Unit rbfeeder.service failed to load properly: Device or resource busy.
See system logs and 'systemctl status rbfeeder.service' for details.
dpkg: error processing package rbfeeder (--configure):
 installed rbfeeder package post-installation script subprocess returned error exit status 1
Seems the package rbfeeder is broken
Try this
Code: [Select]
sudo apt --fix-broken install
sudo reboot
If above fails to fix the issue, try this command
Code: [Select]
sudo dpkg --configure -a
« Last Edit: August 11, 2022, 01:10:43 PM by abcd567 »
« Reply #7 on: August 16, 2022, 07:25:04 PM »
Model Raspberry Pi 3b+
OS : "Raspbian GNU/Linux 11 (bullseye)"
None of the procedures above could fix the issue. I have a doubt. When I execute sudo apt install rbfeeder    rbfeeder dont ask for initial parameters. Is there any way to ERASE DELETE VAPORIZE all RBFEEDER and make a clean installation ??
« Reply #8 on: August 17, 2022, 12:02:47 AM »
Just a simple question. I´ve realized that station key and Station name weren´t asociated, so I´ve edited the Station Name in the rbfeeder.ini file, to match it with the original station key.
Maybe there is another way to do that.
Waiting for answers...
  • CYYZ - Toronto
« Reply #9 on: August 17, 2022, 08:22:49 AM »
OK Try this
(1) Give following commands
Code: [Select]
sudo systemctl stop rbfeeder
sudo dpkg --purge rbfeeder
# NOTE: In command below, replace xxxxxxxxxxxxxxxxxx by your actual key
sudo rbfeeder --setkey xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
(2) Press Ctrl+C to break-out
(3) Stop then restart rbfeeder
Code: [Select]
(4) Check status
Code: [Select]
If above fails, then locate the rbfeeder package by following command
Code: [Select]
sudo find / -name rbfeeder*.deb
The above command will output location of rbfeeder package.  In my Pi it shows like this:
                       /var/cache/apt/archives/rbfeeder_1%3a1.0.8+deb11_armhf.deb
Please post output. This package will need to be deleted, then installation script run
Code: [Select]
sudo rm /var/cache/apt/archives/rbfeeder_1%3a1.0.8+deb11_armhf.deb
« Last Edit: August 18, 2022, 04:49:51 PM by abcd567 »
« Reply #10 on: August 18, 2022, 11:34:26 AM »
Just getting tired... 3 PROVIDERS WORKS PERFECT...
Attached info, because system keeps telling spam... don´t know how you guys copy/paste code/text in this forum and not getting that message...
How could you put those codes lines in green background ?
  • CYYZ - Toronto
« Reply #11 on: August 18, 2022, 04:45:43 PM »
Code: [Select]
Marco@raspberry:~ $ sudo find / -name rbfeeder*.deb
/var/cache/apt/archives/rbfeeder_1%3a1.0.7_armhf.deb
find: ‘/run/user/1000/gvfs’: Permission denied
Oh, I think I found the culprit.
The first two lines of output show that you have two versions of rbfeeder (1.0.7 & 1.0.8) saved in apt cache. Either one or both versions are corrupt, OR presence of two versions is causing conflict.
Let us get rid of all old stuff first
Code: [Select]
sudo rm /var/cache/apt/archives/rbfeeder_1%3a1.0.7_armhf.deb
sudo reboot
After reboot, check that both versions are removed from apt cache by following command. If both are removed, the output of this command wont show them
Code: [Select]
If apt cache is clear of rbfeeder, run the installation script
Code: [Select]
## NOTE: In command below, replace xxxxxxxxxxxxxxxxxx by your actual key
## Output will show your key has been accepted
## Press Ctrl & C keys to break out
Now check status
Code: [Select]
« Reply #12 on: August 19, 2022, 02:57:22 PM »
Good morning, after executind the command given below.....
Code: [Select]
this is the output...
ATTACHED FILE because for some unknown reason to me system keeps telling CleanTalk: *** Forbidden. Please enable JavaScript. Contains contacts. *** enable javascript in 3 different browsers, and cannot copy/paste results here...
That message from sudo find / -name rbfeeder*.deb, means that something cannot be deleted?
revvin´up... damn...
  • CYYZ - Toronto
« Reply #13 on: August 19, 2022, 04:00:50 PM »
Code: [Select]
Great!
This is exactly the message I wanted to see.
It confirms that both versions of rbfeeder have been removed, as they are no more listed in the output. Never mind the line with "Permossion denied". It is always there.
As the apt cacbe has been cleaned now, go ahead to next step and run the installation script
Code: [Select]
When above command finishes installation, add your key by following command
(In command below, replace xxxxxxxxxxxxxxxxxx by your actual key)
Code: [Select]
Output of above command will show your key has been accepted
Now restart rbfeeder
Code: [Select]
Now check status
Code: [Select]
« Reply #14 on: August 19, 2022, 11:41:44 PM »
Will give up with this RADAR****BOX setup... unbelievable....
attached results from status command...
there are a couple of "failed to rename..."
What is annoying is that the other 3 feeders work like a charm...
