Author Topic: RB VHF usb  (Read 9819 times)
D00B
RB VHF usb
« on: September 26, 2022, 05:13:24 PM »
Hello everyone. I’ve recently bought a RB VHF stick and am using a Raspberry Pi 3B on Buster.
I have read the guide here https://www.radarbox.com/sharing-vhf
Something throwing me off is the bit about using RTL-SDR-Airband software. Clicking the link takes me to GitHub but I don’t know what to do there.
If I just go straight to trying sudo apt-get update -y && sudo apt-get install rtl-airband-rb -y via ssh on the pi, I get the response “E: Unable to locate package rtl-airband-rb”
Is anyone pi savvy able to offer some guidance for me?
Thanks in advance.
  • CYYZ - Toronto
Re: RB VHF usb
« Reply #1 on: September 26, 2022, 07:53:48 PM »
You need to add Radarbox repository to your apt sources list.
(1) EASY AUTOMATED METHOD:
If you don't have RBFeeder installed, the following command will install both RBFeeder and the rtl-airband-rb package:
Code: [Select]
sudo bash -c "$(wget -O - http://apt.rb24.com/inst_rtl-airband-rb.sh)"
(2) MANUAL METHOD (FOR ADVANCE USERS)
The screenshot you posted shows you have Raspbian BUSTER.
You can further confirm this by following command
Code: [Select]
lsb_release -sc
Issue following command to add RB24's BUSTER repo to your apt sources list:
Code: [Select]
sudo touch /etc/apt/sources.list.d/rb24.list
sudo chmod 666 /etc/apt/sources.list.d/rb24.list
sudo echo 'deb https://apt.rb24.com/ buster main' > /etc/apt/sources.list.d/rb24.list
sudo chmod 644 /etc/apt/sources.list.d/rb24.list
sudo apt update
Now issue following command to install airband
Code: [Select]
« Last Edit: September 26, 2022, 08:28:19 PM by abcd567 »
D00B
Re: RB VHF usb
« Reply #2 on: September 26, 2022, 08:21:47 PM »
Thanks abcd! I was hoping you come good having read so many of your posts before.
I’ll have a go now and report back.
D00B
Re: RB VHF usb
« Reply #3 on: September 26, 2022, 08:30:17 PM »
There seems to be an error with that
  • CYYZ - Toronto
Re: RB VHF usb
« Reply #4 on: September 26, 2022, 08:37:27 PM »
Try this command:
Code: [Select]
D00B
Re: RB VHF usb
« Reply #5 on: September 26, 2022, 08:58:30 PM »
Ok, that’s done and the conf file is now populated with the information provided in the guide.
My issue now is restarting the service.
The service is not found.
D00B
Re: RB VHF usb
« Reply #6 on: September 26, 2022, 08:59:09 PM »
Here’s the error
  • CYYZ - Toronto
Re: RB VHF usb
« Reply #7 on: September 26, 2022, 09:12:02 PM »
Code: [Select]
Failed to restart rtl-airband-rb. Unit rtl-airband-rb.service not found
The airband did NOT get installed.
The problem is missing PUBLIC KEY F2A8428D3C354953 (see cutout from your first screenshot below)
Add missing key by following command
Code: [Select]
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys  F2A8428D3C354953
Now try again
Code: [Select]
D00B
Re: RB VHF usb
« Reply #8 on: September 27, 2022, 05:03:20 PM »
Thank you! All seems to have gone through correctly. Only issue now is it shows offline on the website which is a little odd
D00B
Re: RB VHF usb
« Reply #9 on: September 30, 2022, 06:57:23 PM »
@abcd567
I seem to have another issue which is causing the service to fail.
If I issue the command
Code: [Select]
sudo systemctl restart rtl-airband-rb.service
I get the following error
Job for rtl-airband-rb.service failed because the control process exited with error code.
See "systemctl status rtl-airband-rb.service" and "journalctl -xe" for details.
Running this
Code: [Select]
offers the response
● rtl-airband-rb.service - SDR AM/NFM demodulator
   Loaded: loaded (/lib/systemd/system/rtl-airband-rb.service; enabled; vendor preset: enable
   Active: failed (Result: exit-code) since Fri 2022-09-30 19:50:54 BST; 2min 18s ago
     Docs: https://github.com/szpajder/RTLSDR-Airband/wiki
  Process: 3564 ExecStart=/usr/bin/rtl_airband -e -c /etc/rtl-airband-rb.conf (code=exited, s
Sep 30 19:50:54 raspberrypi systemd[1]: Starting SDR AM/NFM demodulator...
Sep 30 19:50:54 raspberrypi rtl_airband[3564]: Error while parsing configuration file /etc/rt
Sep 30 19:50:54 raspberrypi systemd[1]: rtl-airband-rb.service: Control process exited, code=
Sep 30 19:50:54 raspberrypi systemd[1]: rtl-airband-rb.service: Failed with result 'exit-code
Sep 30 19:50:54 raspberrypi systemd[1]: Failed to start SDR AM/NFM demodulator.
Looking now at the code for the config using
Code: [Select]
sudo nano /etc/rtl-airband-rb.conf
shows the below which seems to relate to the 3 dots on line 6
The code was originally copied and edited where needed from here https://www.radarbox.com/sharing-vhf
Do you have any thoughts?
D00B
Re: RB VHF usb
« Reply #10 on: September 30, 2022, 07:00:43 PM »
Here is the screenshot of the actual response
