Airband feed - install on Raspberry Pi Bullseye
Started by rx100, January 14, 2023, 11:04:36 PM
rx100
Hello, all, first post.
I have successfully installed RB on a Raspberry Pi and everything is working fine. I wanted to add a RaspberryPi to stream a VHF feed, but I have already spent hours trying to install the Airband Feed software without any success. I have followed the instructions on https://www.radarbox.com/sharing-vhf but somehow, the installation fails because of the version of the Raspberry OS (bullseye). I tried the workaround which consists of faking the OS version but that didn't work either. I think I've hit a dead end :-p
Has someone successfully installed the software ? Can anyone please help ?
Greetings
rupert
#1
Re image your microSD card with RaspberryPiOS Buster, then install all 1090 mhz and Airband software.
Raspberry Pi foundation archives directory for last version of Buster_lite image:
https://downloads.raspberrypi.org/raspbian_lite/images/raspbian_lite-2020-02-14/
Direct download link for last version of Buster Lite image.zip
https://downloads.raspberrypi.org/raspbian_lite/images/raspbian_lite-2020-02-14/2020-02-13-raspbian-buster-lite.zip
rx100
#2
ok, thanks for your reply and the links.
I decided to install icecast on a separate RPi running DietPi (great distro. !) which has icecast bundled. Now I just have to figure out how to link it RB rb 8-0 (the config files are XML).
Another issue i have is MLAT. It is "active" but there are no "stations"....
Otherwise, all is working fine.
Greetings
Aerotower
My icecast2 and rtl_airband works very well with bullseye.
Aerotower
Quote from: rx100 on January 17, 2023, 07:04:56 PM
What do you have inside rbfeeder.ini?
It depends on where you are located and whether there are other MLAT stations within range, what is your station number?
