Author Topic: Help please  (Read 15191 times)
Rural Outpost
  • Still waiting to pick up a DAN AIR HS748 !
Help please
« on: March 05, 2023, 05:34:58 PM »
My lap top has crashed so I am using another one. Can someone please advise how I can download the software onto the new laptop so I can continue to use my radarbox1.I thought about loading my original CD but this laptop doesn't have a CD player. Any advice much appreciated.
Re: Help please
« Reply #1 on: March 05, 2023, 07:14:05 PM »
Download and install V6 from here You can get 6.00.02 here http://www.airnavsystems.com/download/ANRB/ANRB60002Setup.exe
If that link doesnt work use V6.00.03 https://www.airnavsystems.com/download/ANRB/ANRB60003Setup.exe
You will also need the drivers from here https://www.airnavsystems.com/Download/ANRB/Drivers/ANRB-Drivers-20161222.zip
Use your log in details from your original box
« Last Edit: March 05, 2023, 07:17:00 PM by Runway 31 »
Rural Outpost
Re: Help please
« Reply #2 on: March 05, 2023, 08:07:55 PM »
Thank you
CarlosAbreu
  • The sky is not the limit
Re: Help please
« Reply #3 on: March 06, 2023, 12:46:42 AM »
Hi List
What's the diference between my ANRB Radarbox1 6.01.001 and the ones in the post?
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Re: Help please
« Reply #4 on: March 06, 2023, 07:44:27 PM »
Stick to the one you have Carlos  6.00.02 shows as 6.00.01 so its probably what you have. 6.00.03 is modified to allow xrange and Pi's to use it and in doing so some more bugs were introduced
CarlosAbreu
Re: Help please
« Reply #5 on: March 06, 2023, 09:43:19 PM »
Thanks for information.
Carlos
Rural Outpost
Re: Help please
« Reply #6 on: March 07, 2023, 01:53:49 PM »
I have downloaded version 6.00.02 but the system doesn't connect to my RB1. It states no hardware connected. The left blue light on the front of the RB1 is flashing. I assume the drivers are not connected properly? Is there an idiots guide I can follow.
Thank you for your advice so far.
Re: Help please
« Reply #7 on: March 08, 2023, 09:06:32 PM »
Try running the drivers again.  You should be able to see the box in Control Panel and see if the drivers are installed correctly
Also it is possible the USB cable connecting the box to your computer is duff so try another one.  Also try another USB port
Rural Outpost
Re: Help please
« Reply #8 on: March 28, 2023, 10:22:02 AM »
Unfortunately I am still not up and running which is very frustrating. When I download the drivers from the link it automatically saves in my downloads. Is there a specific place should save the drivers into? I am using Windows 10.
Sorry for all the questions and appreciate your help.
Shawn
Re: Help please
« Reply #9 on: March 28, 2023, 03:58:58 PM »
They should go into the Radarbox/Data/Drivers folder
Rural Outpost
Re: Help please
« Reply #10 on: March 28, 2023, 05:32:48 PM »
After almost throwing the laptop out the window I bit the bullet and took my lap top to  a local IT shop. The fella got it running in less than 2 minutes :-)
and it only cost me a fiver.
I am back up and running.
Thanks for your time.
Shawn
Re: Help please
« Reply #11 on: March 29, 2023, 07:41:16 AM »
Good news Shawn, it is usually something simple.  I am having issues with mine on my main computer just now,cant get any stick recognised after V6 running for many years and the sticks are working ok on my laptop.  With working getting routes to add into the database i just dont have the time to fix it just now
Roger
Re: Help please
« Reply #12 on: April 19, 2023, 08:11:12 AM »
I have the same problem. Old PC crashed, new PC installed yesterday. Have downloaded the software from the links above (V6.00.03 and the drivers) and get the blue USB light flashing around once a second, but nothing on the signal light. Have tried the USB cable in an alternate outlet on the new PC. Please help!
Re: Help please
« Reply #13 on: April 19, 2023, 05:53:48 PM »
Are you seeing the receiver in Control Panel/Devices and Printers/Unspecified and is it ok there
Roger
Re: Help please
« Reply #14 on: April 19, 2023, 06:43:42 PM »
No, the receiver is not showing up in Devices or Printers. If I try to add it manually, the PC isn't finding it.
