Author Topic: share audio  (Read 10152 times)
Gadgetman
share audio
« on: March 25, 2023, 01:45:39 AM »
does the audio sharing not work? tried the pi version, states cant find rtl-airband-rb file
Re: share audio
« Reply #1 on: March 25, 2023, 08:32:07 AM »
RZEE
Re: share audio
« Reply #2 on: March 26, 2023, 07:28:48 AM »
Quote
No, it will not work on Bullseye, see topic link above. And yes, it works on Buster, however in Buster you will miss the Mlat. Waiting months for a compatible solution.....
  • CYYZ - Toronto
Re: share audio
« Reply #3 on: March 27, 2023, 08:13:08 PM »
Instead of using one Pi for both ADS-B and AirBand, if you have a spare Pi, install Buster on it and use it for Air Band only.
If you dont have a spare Pi, but are ready to spend some money, you may purchase low cost Pi Zero W. It will be OK for AirBand.
In view of short sypply of Raspberry Pi, Orange Pi Zero or Orange Pi Lite can be had in around US$40 ~ 50. As an example, this set is cost+shipping around US$45 and includes Pi Board, Power Supply, and Case.
https://www.aliexpress.com/item/1005004527521445.html
Gadgetman
Re: share audio
« Reply #4 on: March 28, 2023, 01:48:05 AM »
That’s a possibility, I have a PC next to it that’s not doing much now, can I share via the PC somehow?
  • CYYZ - Toronto
Re: share audio
« Reply #5 on: March 30, 2023, 07:16:07 AM »
Yes, you can.
Feed ONLY AirBand from the Pi by installing Buster on it.
For feeding 1090 MHz, install AirNav RB V6.0002 software on Windows PC and plug the 1090 Dongle in the PC, and feed RB24 1090 MHz through this software.
Download AirNav Radarbox Ver 6.0002 Sotware:
https://www.airnavsystems.com/download/ANRB/ANRB60002Setup.exe
Download Driver:
https://www.airnavsystems.com/Download/ANRB/Drivers/ANRB-Drivers-20161222.zip
NOTE: You cannot login to AirNav Ver 6.0002 software with your RPi feeder key. You will have to create a new station number in format EXTSHAxxxxxx by installing Radarbox24 Data Sharer 1.20 on Windows PC, and logging in with your existing RB24 account's email and password (or create a new RB24 account using another email and password)
Download Radarbox24 Data Sharer 1.20 Software:
http://www.airnavsystems.com/download/rb24/RB24DataShare120Setup.exe
Once you get a Station number EXTSHAxxxxxx through Radarbox24 Data Sharer 1.20, send an email to RB24 Support advising them of this Station number and your email address you used to get this number. Support will link the new Station to your account.
« Last Edit: March 30, 2023, 07:27:20 AM by abcd567 »
Gadgetman
Re: share audio
« Reply #6 on: March 30, 2023, 12:07:27 PM »
thanks for the advice, i already have an ETXSHAxxxxx and all the software required, i stopped using the PC as i cant share MLAT, and thats more important than audio.. my work around is this: running the RPi for sharing data, i have a scanner tuned to the atc channels, i am piping it into my pc, where i have an app called Zello (walkie talkie) style, i have it set to VOX, and i can stream it to both my Ipad and iPhone, works perfectly and i have it attached to a discone antenna thats on my roof…and the ADS-B antenna will be up on another support within the next week or so, weather permitting.
