Author Topic: antenna height  (Read 9150 times)
Gadgetman
antenna height
« on: May 21, 2023, 11:43:18 AM »
should my antenna height be set  for how high it is from the ground or from sea level? my city is 2200 feet above sea level, antenna is 55 feet from the ground at my location
phil
pedrão18
Re: antenna height
« Reply #1 on: May 21, 2023, 07:40:03 PM »
Hello.
Antenna height must be provided in meters, above sea level.
STEP-2: Edit file /etc/rbfeeder.ini, and ADD lines shown in RED to enable mlat
Note:
Use actual values in place of:
xx.xxxxxx (latitude)
yy.yyyyyy (longitude)
zzz  (antenna height, in meters, above sea level)
Re: antenna height
« Reply #2 on: May 21, 2023, 08:34:29 PM »
It is above sea level in feet or meters depending on what you use on RB
Gadgetman
Re: antenna height
« Reply #3 on: May 21, 2023, 08:37:41 PM »
Thanks, i went to change it, i i noticed that the box had already calclated the elevation, and the info for the antenna height stated from ground, once entered, it auto calculated to the correct ehight…
Phil
Re: antenna height
« Reply #4 on: May 21, 2023, 08:46:01 PM »
Cheers Phil
