Author Topic: Sharing stats shows "offline"  (Read 11679 times)
glen4cindy2
« on: August 05, 2023, 03:20:58 PM »
I'm having an issue where my sharing status has been showing as a red line for several hours.
When I browse to my station URL I am seeing planes. My account status is still showing as "business" and I am not receiving email messages indicating they are not receiving data.
I've restarted my Raspberry Pi, and I've restarted rbfeeder as well.
If I ssh into the Pi and issue the command: sudo systemctl status rbfeeder this is my output:
     Active: active (running) since Sat 2023-08-05 10:04:12 CDT; 2min 29s ago
    Process: 7614 ExecStartPre=/bin/mkdir /var/run/rbfeeder (code=exited, status=1/FAILURE)
    Process: 7615 ExecStartPre=/bin/chown rbfeeder:rbfeeder /var/run/rbfeeder (code=exited, status=0/SUCCESS)
    Process: 7616 ExecStartPre=/bin/touch /var/log/rbfeeder.log (code=exited, status=0/SUCCESS)
    Process: 7617 ExecStartPre=/bin/chown rbfeeder:rbfeeder /var/log/rbfeeder.log (code=exited, status=0/SUCCESS)
    Process: 7618 ExecStartPre=/bin/chown rbfeeder:rbfeeder /etc/rbfeeder.ini (code=exited, status=0/SUCCESS)
    Process: 7619 ExecStartPre=/bin/setfacl -m u:www-data:rwx /etc/rbfeeder.ini (code=exited, status=0/SUCCESS)
   Main PID: 7620 (rbfeeder)
      Tasks: 9 (limit: 1598)
        CPU: 1.495s
             └─7620 /usr/bin/rbfeeder
Aug 05 10:05:12 raspberrypi rbfeeder[7620]: [2023-08-05 10:05:12]  Data sent: 67 B
Aug 05 10:05:12 raspberrypi rbfeeder[7620]: [2023-08-05 10:05:12]  Data received: 28 B
Aug 05 10:05:23 raspberrypi rbfeeder[7620]: [2023-08-05 10:05:23]  Connection established.
Aug 05 10:05:23 raspberrypi rbfeeder[7620]: [2023-08-05 10:05:23]  Client type: Raspberry Pi
Aug 05 10:05:23 raspberrypi rbfeeder[7620]: [2023-08-05 10:05:23]  Connection with RadarBox24 server OK! Key accepted by server.
Aug 05 10:05:23 raspberrypi rbfeeder[7620]: [2023-08-05 10:05:23]  This is your station serial number: EXTRPI001018
Aug 05 10:06:13 raspberrypi rbfeeder[7620]: [2023-08-05 10:06:13]  ******** Statistics updated every 60 seconds ********
Aug 05 10:06:13 raspberrypi rbfeeder[7620]: [2023-08-05 10:06:13]  Packets sent in the last 60 seconds: 670, Total packets sent since sta>
Aug 05 10:06:13 raspberrypi rbfeeder[7620]: [2023-08-05 10:06:13]  Data sent: 23.0 KB
Aug 05 10:06:13 raspberrypi rbfeeder[7620]: [2023-08-05 10:06:13]  Data received: 59 B
Do I need to be concerned about this or is there some issue going on?
Thanks in advance.
Re: Sharing stats shows "offline"
« Reply #1 on: August 06, 2023, 01:45:11 PM »
I presume that it is an issue at the server end with the statistic script.  That fact that you are seeing aircraft on your feed shows that you are online so nothing to worry about.  It will be fixed and all will be ok
Just looked at your station, all ok, no red so I presume that it has already been fixed
« Last Edit: August 06, 2023, 01:50:50 PM by Runway 31 »
pedrão18
« Reply #2 on: August 06, 2023, 04:52:25 PM »
I am also having this same problem.
My station shows offline since yesterday, however nothing in the logs shows any connection errors and it is sending data normally
« Last Edit: August 06, 2023, 08:05:56 PM by pedrão18 »
glen4cindy2
« Reply #3 on: August 06, 2023, 07:38:57 PM »
Thanks Alan.
I'm still red but I appreciate you looking into this for me.
Glen
« Reply #4 on: August 06, 2023, 08:22:40 PM »
Dont know where its red Glen its all green here, see attached
Where are you seeing red?
glen4cindy2
« Reply #5 on: August 10, 2023, 09:17:16 PM »
It's not showing red anymore. It was when I posted this issue.
The bottom row had a small blip of red that grew longer and longer.
All of a sudden it was all green again.
It must have been a glitch.
« Reply #6 on: August 11, 2023, 09:25:46 AM »
When the script has an issue and goes red, after it is fixed it goes green
