Author Topic: RadarBox 6.02.003 Non ADS-B display  (Read 9356 times)
gilemery
« on: August 30, 2023, 06:27:03 PM »
New to Radarbox.
I see a flight listed in My Flights that is a Non ADS-B flight, but it does not display on the map directory (It was a local ANG tanker if that matters)
Does it not display on the map because it is a military flight that perhaps does not share long/lat, but will display on the list of My Flights?
    • Rod's RadarBox Downloads
Re: RadarBox 6.02.003 Non ADS-B display
« Reply #1 on: August 31, 2023, 10:57:10 AM »
Hi gilemery
ADS-B includes position data, so with no ADS-B, no position, so it can't appear on the map. Many military aircraft are fitted with ADS-B but can turn it off if they don't want to be for example, shot down.
Hope that helps
« Reply #2 on: August 31, 2023, 05:30:57 PM »
It should display on the list but not on the map as detailed by Rod.  It will usually be squitting mode-s which will let you know it is there but not where
