linux starter documents?
Started by ivo, October 23, 2023, 11:09:02 PM
ivo
I purchased a USB stick ADSB radar box and antenna.  I connected it to a new ubuntu 22.04 server installation on an x86_64 computer.  (ebay sells old asus chromebox computers for about $50, which seem good for this purpose.). the ubuntu install on the asus device immediately shows up on the /var/log/kern* .
now I need to start installing linux software that reads data from it and interprets it.
1. it is my understanding that dump1090 is the way to start (though there are a few versions of it, and ubuntu itself does not distribute it, but some hobbyists).  alas, the one I tried seems to depend on libraries, header files, etc., that are not standard on ubuntu and do not come with the dump1090 distributions I found.  I don't think the vendor distributes a software starter kit for linux, either.  (I did see that they distribute a feeder to their website.)
2. I then want to keep a record of the airplanes that are flying directly over me.  presumably, I can then take the output of dump1090 and look for records of a particular type.
has anyone put together a document of what needs to be installed in what order and how to interpret the output?  pointers appreciated.
Ivo
For installing the RB feeder on Linux see https://www.radarbox.com/sharing-data/guide it comes with its own dump 1090
Regarding your other query I am not aware of anyway to do this but then again I dont know Linux
#2
Hi Alan & IVO
The Guide is for RPi (arm CPU) only. Radarbox24 do NOT have any package for installation on x86_64 machines, so the guide you are referring is useless for ivo.
However radarbox feeder can be installed on Linux x86_64 computers through Docker.
https://github.com/sdr-enthusiasts/docker-radarbox
The decoder offered by this Docker site is readsb. However if ivo dont like readsb, he can install dump1090-mutability, which is readily available in Ubuntu 22.04, and can very easily be installed by following command:
Quote
sudo apt install dump1090-mutability
Please see screenshot of my Ubuntu 22.04 on x86_64  machine with dump1090-mutability installed by above command.
Click on Screenshot to see larger size.
Thanks abc, want aware of the difference
ivo
thank you.  dump1090-mutability with apt worked beautifully.
@IVO
Glad to know you could install dump1090-mutability and it is working good.
Now you can go to the Docker site I have linked in my previous post and install rbfeeder docker.
Please be careful. They not only offer rbfeeder but also readsb-protobuf. As you have already installed dump1090-mutability, there is no need to install readsb-protobuf. Not only that you dont need it, but installing it will collapse your feed as both readsb and dum1090 will compete for dongle and ports, and there will be a clash, and yor system will become a mess. You should have only ONE of the two decoders installed, either dump1090-mutability or readsb-protobuf.
