Author Topic: MLAT from Flightfeeder  (Read 10690 times)
jelle
« on: November 03, 2023, 06:54:53 AM »
I have a Flightfeeder (v10) running here at home. I was able to send the data from this via my rp3 to radarbox. MLAT seems to be active but will never sync. Has anyone set this up succesfully? I'm unsure where I should start looking. Below is my rbfeeder.ini
It says MLAT active (No stations synced).
Quote
[client]
network_mode=true
key=xxx
sn=xxx
lat=xxxx
lon=xxx
alt=43
[network]
mode=beast
external_port=30005
external_host=192.168.68.66
[mlat]
autostart_mlat=true
[dump978]
dump978_enabled=false
  • CYYZ - Toronto
Re: MLAT from Flightfeeder
« Reply #1 on: November 06, 2023, 09:58:33 PM »
What is version of your
(1) RPi 3 OS
(2) mlat client
Please post outputs of following commands which will show above noted information:
Code: [Select]
lsb_release -a
apt-cache policy mlat-client
