I'm so close, but so far away. So far, I've become proficient at installing an OS and serializing dongles; although I have yet to get the system to be correctly configured, I've demonstrated that my inferior antenna works just fine -
but when I take the Pi up to the "better" antenna with a saw-bird attached, I lose everything.. the dongles are still serialized, but somehow between the shutdown and reboot the system forgets what I just had it doing. I'm sure it's a simple setting that has already been posted, but when I don't even really know what to search for, I struggle in the plethora of frequently conflicting information.
The packages I sent yesterday were done by ignoring the above errors and attempting the install prescribed by ACBD567 for Bookworm - (thank you, very much, for that). If I attempt adding other feeders, or even just moving the Pi to a more suitable location than where I set it up at I'm losing everything.
At present, my dongles are serial numbers 00000978 and 00001090.
