Author Topic: Radarbox 6.02.003  (Read 13275 times)
vassylad
Radarbox 6.02.003
« on: April 12, 2024, 04:13:54 PM »
Good after thanks for the welcome
I am currently using the above program to run my radarbox, I have a static yellow power light a flashing blue USB light and a weak blue signal flashing light, in the program it states that the hardware is not connected please help
thanks Michael
Re: Radarbox 6.02.003
« Reply #1 on: April 13, 2024, 06:39:18 PM »
Michael
Have you just started using the box or has it been in use for a while
vassylad
« Reply #2 on: April 17, 2024, 11:17:20 AM »
Good morning Alan I have had the box for a good few years now, i found it again whilst looking for something else and its not been used for over 2 years or more i would imagine, it was very good back in the day and i would love to see it working again, i am using an external antenna but alas I cant seem to get any results
Thanks Michael
« Reply #3 on: April 18, 2024, 08:43:46 AM »
Hi Michael
I presume that you are still trying it with the software that came with the box, that will probably not work now so I suggest you delete it from your computer
Download and install https://www.airnavsystems.com/download/ANRB/ANRB60003Setup.exe then the drivers https://www.airnavsystems.com/Download/ANRB/Drivers/ANRB-Drivers-20161222.zip
vassylad
« Reply #4 on: April 18, 2024, 11:58:53 AM »
Good afternoon Alan, firstly thanks for the reply and software updates etc, I had a CD with the radarbox which i have misplaced, but alas i could not use it anyway, the only software/drivers that I currently have on my PC are the ones I have downloaded recently.
I have followed your advice and downloaded the links, but alas the flashing USB blue light I think needs to be stable and not flashing for me to get some results.
I am currently using SDRuno with a plugin for ADSB which works quite well through Virtual radar, do you think that there is a possibility of using it through the radar box? but it probably means me stabilising the USB light first.
Any thought Michael
« Last Edit: April 18, 2024, 12:00:45 PM by vassylad »
« Reply #5 on: April 18, 2024, 08:56:56 PM »
Ate you getting a green connected light bottom left of the V6 screen
I have no idea on SDRuno with a plugin for ADSB. never heard of it.  Every possibility the box is knackered and you may want to consider a USB stick instead.  USB sticks a fairly cheap
vassylad
« Reply #6 on: April 25, 2024, 08:47:48 AM »
Good morning Alan can you point me in the direction of a decent radar box USB stick please I just want to connect it to the software, what would you recommend for a decent adsb antenna or something to run along side the stick
Thanks Michael
« Reply #7 on: April 25, 2024, 07:16:14 PM »
Hi Michael
The Airnav Flightstick is descent and it can connect to your existing antenna and V6
https://www.amazon.co.uk/AirNav-RadarBox-FlightStick-Advanced-Receiver/dp/B07K47P7XD
vassylad
« Reply #8 on: April 26, 2024, 09:22:23 AM »
Ordered and thank you Alan
regards
Michael
