Author Topic: Up and running  (Read 20752 times)
vassylad
Up and running
« on: May 01, 2024, 06:59:44 PM »
well after contacting airnav direct I am finally up and running phew, I have a few questions if I may the latest version is running slowly on my pc and although I have good internet its buffering sometimes which is annoying. FTP upload status disconnected what is this and do i need it, can i turn of real time network I just want to see what | am picking up through my antenna, when I open file and preferences what details do I need to fill in from the above  General legends and labels Radarbox (enter IP address} port 32008 is this correct home station data, what is a good antenna for the flightstick
Michael
Re: Up and running
« Reply #1 on: May 01, 2024, 08:32:05 PM »
Hi Michael
Got your PM, been busy today.
Regarding the network, it is up to you weather you run it or not.  With 10,000 live flights to process every 20 seconds it is very processor intensive.  Its easy to switch off, just untick Get Flights from Radarbox Network bottom left on the network page.  That way you are only seeing the flights your rceiver is picking up om the My Flights tab
FTP ignore it
As a start I would suggest the following options
Map untick Vertical Tracking View
Tools/Interface on Left
Preferences - General  leave as is
Preferences - Legends and Labels  leave as is
Preferences - Radarbox  Tick Share Flight Data
                                    Photo and Aircraft Auto Populate  tick all
                                    Route Auto Populate tick auto popuate
                                    Leave the rest as is
                                    Click Apply and OK before leaving page
Preferences Home Station Data  enter you Lat/Lon in deciaml format
After that its up to you alter any setting as you like
  • CYYZ - Toronto
Re: Up and running
« Reply #2 on: May 02, 2024, 12:41:39 AM »
How to disable network flights in ANRB V6
https://forum.radarbox24.com/index.php?topic=103981.msg462651#msg462651
Click on attached screenshot to see larger size.
« Last Edit: May 02, 2024, 12:45:19 AM by abcd567 »
Re: Up and running
« Reply #3 on: May 02, 2024, 09:46:26 AM »
Michael, whats your PGANRB****** number
vassylad
Re: Up and running
« Reply #4 on: May 02, 2024, 07:40:22 PM »
PGANRB10621
PS A massive thanks for all your help today
Michael
« Last Edit: May 02, 2024, 07:44:15 PM by vassylad »
Re: Up and running
« Reply #5 on: May 03, 2024, 12:17:29 PM »
No Problem Michael, any further queries please ask
Regarding your PGANRB number, there appears to be a number missing
vassylad
Re: Up and running
« Reply #6 on: May 05, 2024, 03:43:20 PM »
Hi the box says ANRB10621
Michael
Re: Up and running
« Reply #7 on: May 05, 2024, 04:30:58 PM »
Thanks for repying Michael, however theres a number missing, all stations have 6 numbers.
I was just wanting to look at your receiver on RB24 to see your coverage.  As you are feeding you eligble to have a business account on Radarbox and will be able to download and install the RB app on your phone without charge if you would like it
vassylad
Re: Up and running
« Reply #8 on: May 08, 2024, 08:49:16 AM »
Good morning pal yeah I am pretty pleased with the free upgrade, I have recently purchased a new ADSB antenna and its very good albeit that I am pretty well surrounded by trees on all sides that my range is only 170 miles, maybe i will have better luck in the autumn.
Okay a few questions is the flightstick better than the original radarbox of which I am still trying to get it connected and if I do will it clash with the flightstick?
What do the colours red green and blue signify on the radarbox screen
Is it worth getting an ACARS decoder and can I use the same ADSB antenna
Michael
Re: Up and running
« Reply #9 on: May 09, 2024, 06:41:35 PM »
Red climbing
Green descending
Blue level flight
ACARS requires radio and an antenna I believe
Flightstick will be better than the original box as it has newer electronics
vassylad
Re: Up and running
« Reply #10 on: May 09, 2024, 06:48:04 PM »
Thanks buddy
vassylad
Re: Up and running
« Reply #11 on: May 14, 2024, 03:32:47 PM »
Good afternoon looking at my radarbox screen i have Altitude GS IAS Vrate and squawk I had NM nautical miles last time i looked how do I get it back please, also on my mobile using my station I get the aircraft but no details but I get everything on the laptop, lastly I want to upgrade from my laptop to a bigger monitor any ideas what i need to do
thanks Michael
Re: Up and running
« Reply #12 on: May 14, 2024, 05:32:17 PM »
Michael
File/Preferences/Legends and Lables/Grid Visible Columns and tick Dist(NM)
Regarding the monitor, couple of ways you can do it, either by a computer and monitor or connect a monitor to your laptop using an appropriate cable, if its a newish computer it may have a HDMI port to connect to a monitor
Regarding details on the app, click on the 3 dotd, bottom left, click map options and move the slider for Show Labels and the sliders for what detail you want on the lables
vassylad
Re: Up and running
« Reply #13 on: May 14, 2024, 05:57:40 PM »
Thanks Alan always a fantastic reply
Michael
vassylad
Re: Up and running
« Reply #14 on: May 15, 2024, 01:40:51 PM »
Hi i am getting military aircraft in my log but not actually seeing any can I see them with the civil aircraft, I am sure there is a way
Thanks Michael
