Author Topic: Constantly restarting rbfeeder binary  (Read 14068 times)
Randstad
« on: July 05, 2024, 07:57:50 PM »
Hi, I am running docker-readsb-protobuf + docker-radarbox. I have a problem with the latest version of docker-radarbox. Suddenly, every few minutes I get this error:
Code: [Select]
No packets received from readsb:30005. Restarting rbfeeder binary
Is this a known issue?
radarbox container log:
Code: [Select]
[2024-07-05 21:04:18.636][rbfeeder] Receiver: connected   458.1 msg/s received       83.8 msg/s processed (18%)
[2024-07-05 21:04:18.636][rbfeeder] Server:   ready         0.0 kB/s from server      0.5 kB/s to server
[2024-07-05 21:04:18.636][rbfeeder] Results:  0.0 positions/minute
[2024-07-05 21:04:18.636][rbfeeder] Aircraft: 1 of 14 Mode S, 22 of 30 ADS-B used
[2024-07-05 21:08:09.168][stats] Packets sent in past 5 minutes: 5304, total packets since container start: 2579
[2024-07-05 21:08:14.648][watchdog] [WARNING] No packets received from readsb:30005. Restarting rbfeeder binary
[2024-07-05 21:08:22.147][rbfeeder] [2024-07-05 21:08:22]  Starting RBFeeder Version 1.0.10 (build 20231120150000)
[2024-07-05 21:08:22.150][rbfeeder] [2024-07-05 21:08:22]  Using configuration file: /etc/rbfeeder.ini
[2024-07-05 21:08:22.151][rbfeeder] [2024-07-05 21:08:22]  Network-mode enabled.
[2024-07-05 21:08:22.151][rbfeeder] [2024-07-05 21:08:22]  Remote host to fetch data: 172.19.0.5
[2024-07-05 21:08:22.152][rbfeeder] [2024-07-05 21:08:22]  Remote port: 30005
[2024-07-05 21:08:22.152][rbfeeder] [2024-07-05 21:08:22]  Remote protocol: BEAST
[2024-07-05 21:08:22.235][rbfeeder] [2024-07-05 21:08:22]  Using GNSS (when available)
[2024-07-05 21:08:22.275][rbfeeder] [2024-07-05 21:08:22]  Start date/time: 2024-07-05 21:08:21
[2024-07-05 21:08:22.369][rbfeeder] [2024-07-05 21:08:22]  Socket for ANRB created. Waiting for connections on port 32088
[2024-07-05 21:08:22.988][rbfeeder] mlat-client 0.4.2 starting up
[2024-07-05 21:08:22.989][rbfeeder] Listening for Beast-format results connection on port 30105
[2024-07-05 21:08:23.036][rbfeeder] Connected to multilateration server at mlat1.rb24.com:40900, handshaking
[2024-07-05 21:08:23.054][rbfeeder] Server says:
[2024-07-05 21:08:23.054][rbfeeder]         AirNav Server
[2024-07-05 21:08:23.054][rbfeeder]         The multilateration server source code is available under
[2024-07-05 21:08:23.054][rbfeeder]         the terms of the Affero GPL (v3 or later). You may obtain
[2024-07-05 21:08:23.054][rbfeeder]         a copy of this server's source code at the following
[2024-07-05 21:08:23.054][rbfeeder]         location: https://github.com/adsbexchange/mlat-server
[2024-07-05 21:08:23.055][rbfeeder] Handshake complete: Compression zlib2, UDP transport disabled, Split sync disabled
[2024-07-05 21:08:23.055][rbfeeder] Input connected to 127.0.0.1:32457
[2024-07-05 21:08:23.056][rbfeeder] Input format changed to BEAST, 12MHz clock
[2024-07-05 21:08:23.407][rbfeeder] [2024-07-05 21:08:23]  Connection established.
[2024-07-05 21:08:23.526][rbfeeder] [2024-07-05 21:08:23]  Connection with RadarBox24 server OK! Key accepted by server.
[2024-07-05 21:08:23.527][rbfeeder] [2024-07-05 21:08:23]  This is your station serial number: EXTRPIXXXX
[2024-07-05 21:08:23.536][rbfeeder] [2024-07-05 21:08:23]  Client type: Raspberry Pi
[2024-07-05 21:08:23.658][rbfeeder] Beast-format results connection with 127.0.0.1:32004: connection established
[2024-07-05 21:08:51.582][rbfeeder] Accepted Beast-format results connection from ::ffff:172.19.0.6:41378
[2024-07-05 21:09:23.209][rbfeeder] Receiver: connected   324.4 msg/s received      149.4 msg/s processed (46%)
[2024-07-05 21:09:23.209][rbfeeder] Server:   ready         0.0 kB/s from server      0.8 kB/s to server
[2024-07-05 21:09:23.209][rbfeeder] Results:  8.0 positions/minute
[2024-07-05 21:09:23.209][rbfeeder] Aircraft: 2 of 16 Mode S, 18 of 25 ADS-B used
[2024-07-05 21:13:10.921][stats] Packets sent in past 5 minutes: 7491, total packets since container start: 2187
[2024-07-05 21:13:18.795][watchdog] [WARNING] No packets received from readsb:30005. Restarting rbfeeder binary
[2024-07-05 21:13:26.552][rbfeeder] [2024-07-05 21:13:26]  Starting RBFeeder Version 1.0.10 (build 20231120150000)
[2024-07-05 21:13:26.555][rbfeeder] [2024-07-05 21:13:26]  Using configuration file: /etc/rbfeeder.ini
[2024-07-05 21:13:26.555][rbfeeder] [2024-07-05 21:13:26]  Network-mode enabled.
[2024-07-05 21:13:26.556][rbfeeder] [2024-07-05 21:13:26]  Remote host to fetch data: 172.19.0.5
[2024-07-05 21:13:26.556][rbfeeder] [2024-07-05 21:13:26]  Remote port: 30005
[2024-07-05 21:13:26.557][rbfeeder] [2024-07-05 21:13:26]  Remote protocol: BEAST
[2024-07-05 21:13:26.642][rbfeeder] [2024-07-05 21:13:26]  Using GNSS (when available)
[2024-07-05 21:13:26.685][rbfeeder] [2024-07-05 21:13:26]  Start date/time: 2024-07-05 21:13:26
[2024-07-05 21:13:26.778][rbfeeder] [2024-07-05 21:13:26]  Socket for ANRB created. Waiting for connections on port 32088
[2024-07-05 21:13:27.410][rbfeeder] mlat-client 0.4.2 starting up
[2024-07-05 21:13:27.410][rbfeeder] Listening for Beast-format results connection on port 30105
[2024-07-05 21:13:27.459][rbfeeder] Connected to multilateration server at mlat1.rb24.com:40900, handshaking
[2024-07-05 21:13:27.513][rbfeeder] Server says:
[2024-07-05 21:13:27.513][rbfeeder]         AirNav Server
[2024-07-05 21:13:27.513][rbfeeder]         The multilateration server source code is available under
[2024-07-05 21:13:27.513][rbfeeder]         the terms of the Affero GPL (v3 or later). You may obtain
[2024-07-05 21:13:27.513][rbfeeder]         a copy of this server's source code at the following
[2024-07-05 21:13:27.513][rbfeeder]         location: https://github.com/adsbexchange/mlat-server
[2024-07-05 21:13:27.514][rbfeeder]
[2024-07-05 21:13:27.514][rbfeeder] Handshake complete: Compression zlib2, UDP transport disabled, Split sync disabled
[2024-07-05 21:13:27.515][rbfeeder] Input connected to 127.0.0.1:32457
[2024-07-05 21:13:27.515][rbfeeder] Input format changed to BEAST, 12MHz clock
[2024-07-05 21:13:27.815][rbfeeder] [2024-07-05 21:13:27]  Connection established.
[2024-07-05 21:13:27.949][rbfeeder] [2024-07-05 21:13:27]  Client type: Raspberry Pi
[2024-07-05 21:13:28.033][rbfeeder] [2024-07-05 21:13:28]  Connection with RadarBox24 server OK! Key accepted by server.
[2024-07-05 21:13:28.034][rbfeeder] [2024-07-05 21:13:28]  This is your station serial number: EXTRPIXXXX
[2024-07-05 21:13:28.118][rbfeeder] Beast-format results connection with 127.0.0.1:32004: connection established
[2024-07-05 21:13:55.998][rbfeeder] Accepted Beast-format results connection from ::ffff:172.19.0.6:37666
[2024-07-05 21:14:27.609][rbfeeder] Receiver: connected   392.4 msg/s received      197.9 msg/s processed (50%)
[2024-07-05 21:14:27.609][rbfeeder] Server:   ready         0.0 kB/s from server      1.2 kB/s to server
[2024-07-05 21:14:27.609][rbfeeder] Results:  24.9 positions/minute
[2024-07-05 21:14:27.609][rbfeeder] Aircraft: 3 of 12 Mode S, 20 of 30 ADS-B used
[2024-07-05 21:18:12.964][stats] Packets sent in past 5 minutes: 10001, total packets since container start: 2510
[2024-07-05 21:18:22.935][watchdog] [WARNING] No packets received from readsb:30005. Restarting rbfeeder binary
[2024-07-05 21:18:30.976][rbfeeder] [2024-07-05 21:18:30]  Starting RBFeeder Version 1.0.10 (build 20231120150000)
[2024-07-05 21:18:30.979][rbfeeder] [2024-07-05 21:18:30]  Using configuration file: /etc/rbfeeder.ini
[2024-07-05 21:18:30.980][rbfeeder] [2024-07-05 21:18:30]  Network-mode enabled.
[2024-07-05 21:18:30.981][rbfeeder] [2024-07-05 21:18:30]  Remote host to fetch data: 172.19.0.5
[2024-07-05 21:18:30.981][rbfeeder] [2024-07-05 21:18:30]  Remote port: 30005
[2024-07-05 21:18:30.982][rbfeeder] [2024-07-05 21:18:30]  Remote protocol: BEAST
[2024-07-05 21:18:31.063][rbfeeder] [2024-07-05 21:18:31]  Using GNSS (when available)
[2024-07-05 21:18:31.104][rbfeeder] [2024-07-05 21:18:31]  Start date/time: 2024-07-05 21:18:30
[2024-07-05 21:18:31.200][rbfeeder] [2024-07-05 21:18:31]  Socket for ANRB created. Waiting for connections on port 32088
[2024-07-05 21:18:31.842][rbfeeder] mlat-client 0.4.2 starting up
[2024-07-05 21:18:31.842][rbfeeder] Listening for Beast-format results connection on port 30105
[2024-07-05 21:18:31.903][rbfeeder] Connected to multilateration server at mlat1.rb24.com:40900, handshaking
[2024-07-05 21:18:31.934][rbfeeder] Server says:
[2024-07-05 21:18:31.934][rbfeeder]         AirNav Server
[2024-07-05 21:18:31.934][rbfeeder]         The multilateration server source code is available under
[2024-07-05 21:18:31.934][rbfeeder]         the terms of the Affero GPL (v3 or later). You may obtain
[2024-07-05 21:18:31.934][rbfeeder]         a copy of this server's source code at the following
[2024-07-05 21:18:31.934][rbfeeder]         location: https://github.com/adsbexchange/mlat-server
[2024-07-05 21:18:31.935][rbfeeder] Handshake complete: Compression zlib2, UDP transport disabled, Split sync disabled
[2024-07-05 21:18:31.935][rbfeeder] Input connected to 127.0.0.1:32457
[2024-07-05 21:18:31.936][rbfeeder] Input format changed to BEAST, 12MHz clock
[2024-07-05 21:18:32.239][rbfeeder] [2024-07-05 21:18:32]  Connection established.
[2024-07-05 21:18:32.357][rbfeeder] [2024-07-05 21:18:32]  Connection with RadarBox24 server OK! Key accepted by server.
[2024-07-05 21:18:32.358][rbfeeder] [2024-07-05 21:18:32]  This is your station serial number: EXTRPIXXXX
[2024-07-05 21:18:32.368][rbfeeder] [2024-07-05 21:18:32]  Client type: Raspberry Pi
[2024-07-05 21:18:32.540][rbfeeder] Beast-format results connection with 127.0.0.1:32004: connection established
[2024-07-05 21:19:00.447][rbfeeder] Accepted Beast-format results connection from ::ffff:172.19.0.6:46576
[2024-07-05 21:19:32.117][rbfeeder] Receiver: connected   429.4 msg/s received      188.8 msg/s processed (44%)
[2024-07-05 21:19:32.117][rbfeeder] Server:   ready         0.0 kB/s from server      1.2 kB/s to server
[2024-07-05 21:19:32.117][rbfeeder] Results:  23.9 positions/minute
[2024-07-05 21:19:32.117][rbfeeder] Aircraft: 3 of 16 Mode S, 18 of 31 ADS-B used
[2024-07-05 21:23:15.219][stats] Packets sent in past 5 minutes: 12832, total packets since container start: 2831
[2024-07-05 21:23:27.075][watchdog] [WARNING] No packets received from readsb:30005. Restarting rbfeeder binary
[2024-07-05 21:23:35.421][rbfeeder] [2024-07-05 21:23:35]  Starting RBFeeder Version 1.0.10 (build 20231120150000)
[2024-07-05 21:23:35.423][rbfeeder] [2024-07-05 21:23:35]  Using configuration file: /etc/rbfeeder.ini
[2024-07-05 21:23:35.424][rbfeeder] [2024-07-05 21:23:35]  Network-mode enabled.
[2024-07-05 21:23:35.424][rbfeeder] [2024-07-05 21:23:35]  Remote host to fetch data: 172.19.0.5
[2024-07-05 21:23:35.424][rbfeeder] [2024-07-05 21:23:35]  Remote port: 30005
[2024-07-05 21:23:35.424][rbfeeder] [2024-07-05 21:23:35]  Remote protocol: BEAST
[2024-07-05 21:23:35.506][rbfeeder] [2024-07-05 21:23:35]  Using GNSS (when available)
[2024-07-05 21:23:35.547][rbfeeder] [2024-07-05 21:23:35]  Start date/time: 2024-07-05 21:23:35
[2024-07-05 21:23:35.636][rbfeeder] [2024-07-05 21:23:35]  Socket for ANRB created. Waiting for connections on port 32088
[2024-07-05 21:23:36.275][rbfeeder] mlat-client 0.4.2 starting up
[2024-07-05 21:23:36.276][rbfeeder] Listening for Beast-format results connection on port 30105
[2024-07-05 21:23:36.329][rbfeeder] Connected to multilateration server at mlat1.rb24.com:40900, handshaking
[2024-07-05 21:23:36.349][rbfeeder] Server says:
[2024-07-05 21:23:36.349][rbfeeder]         AirNav Server
[2024-07-05 21:23:36.349][rbfeeder]         The multilateration server source code is available under
[2024-07-05 21:23:36.349][rbfeeder]         the terms of the Affero GPL (v3 or later). You may obtain
[2024-07-05 21:23:36.349][rbfeeder]         a copy of this server's source code at the following
[2024-07-05 21:23:36.349][rbfeeder]         location: https://github.com/adsbexchange/mlat-server
[2024-07-05 21:23:36.350][rbfeeder] Handshake complete: Compression zlib2, UDP transport disabled, Split sync disabled
[2024-07-05 21:23:36.350][rbfeeder] Input connected to 127.0.0.1:32457
[2024-07-05 21:23:36.351][rbfeeder] Input format changed to BEAST, 12MHz clock
[2024-07-05 21:23:36.673][rbfeeder] [2024-07-05 21:23:36]  Connection established.
[2024-07-05 21:23:36.810][rbfeeder] [2024-07-05 21:23:36]  Client type: Raspberry Pi
[2024-07-05 21:23:36.891][rbfeeder] [2024-07-05 21:23:36]  Connection with RadarBox24 server OK! Key accepted by server.
[2024-07-05 21:23:36.892][rbfeeder] [2024-07-05 21:23:36]  This is your station serial number: EXTRPIXXXX
[2024-07-05 21:23:36.953][rbfeeder] Beast-format results connection with 127.0.0.1:32004: connection established
[2024-07-05 21:24:04.853][rbfeeder] Accepted Beast-format results connection from ::ffff:172.19.0.6:59764
[2024-07-05 21:24:36.665][rbfeeder] Receiver: connected   394.3 msg/s received       76.6 msg/s processed (19%)
[2024-07-05 21:24:36.665][rbfeeder] Server:   ready         0.0 kB/s from server      0.6 kB/s to server
[2024-07-05 21:24:36.665][rbfeeder] Results:  15.9 positions/minute
[2024-07-05 21:24:36.665][rbfeeder] Aircraft: 2 of 15 Mode S, 17 of 25 ADS-B used
[2024-07-05 21:28:17.703][stats] Packets sent in past 5 minutes: 14940, total packets since container start: 2108
[b][2024-07-05 21:28:31.239][watchdog] [WARNING] No packets received from readsb:30005. Restarting rbfeeder binary
[2024-07-05 21:28:39.854][rbfeeder] [2024-07-05 21:28:39]  Starting RBFeeder Version 1.0.10 (build 20231120150000)
[2024-07-05 21:28:39.857][rbfeeder] [2024-07-05 21:28:39]  Using configuration file: /etc/rbfeeder.ini
[2024-07-05 21:28:39.857][rbfeeder] [2024-07-05 21:28:39]  Network-mode enabled.
[2024-07-05 21:28:39.858][rbfeeder] [2024-07-05 21:28:39]  Remote host to fetch data: 172.19.0.5
[2024-07-05 21:28:39.858][rbfeeder] [2024-07-05 21:28:39]  Remote port: 30005
[2024-07-05 21:28:39.859][rbfeeder] [2024-07-05 21:28:39]  Remote protocol: BEAST
[2024-07-05 21:28:39.941][rbfeeder] [2024-07-05 21:28:39]  Using GNSS (when available)
[2024-07-05 21:28:39.983][rbfeeder] [2024-07-05 21:28:39]  Start date/time: 2024-07-05 21:28:39
[2024-07-05 21:28:40.077][rbfeeder] [2024-07-05 21:28:40]  Socket for ANRB created. Waiting for connections on port 32088
[2024-07-05 21:28:40.714][rbfeeder] mlat-client 0.4.2 starting up
[2024-07-05 21:28:40.715][rbfeeder] Listening for Beast-format results connection on port 30105
[2024-07-05 21:28:40.766][rbfeeder] Connected to multilateration server at mlat1.rb24.com:40900, handshaking
[2024-07-05 21:28:40.792][rbfeeder] Server says:
[2024-07-05 21:28:40.792][rbfeeder]         AirNav Server
[2024-07-05 21:28:40.792][rbfeeder]         The multilateration server source code is available under
[2024-07-05 21:28:40.792][rbfeeder]         the terms of the Affero GPL (v3 or later). You may obtain
[2024-07-05 21:28:40.792][rbfeeder]         a copy of this server's source code at the following
[2024-07-05 21:28:40.792][rbfeeder]         location: https://github.com/adsbexchange/mlat-server
[2024-07-05 21:28:40.792][rbfeeder] Handshake complete: Compression zlib2, UDP transport disabled, Split sync disabled
[2024-07-05 21:28:40.793][rbfeeder] Input connected to 127.0.0.1:32457
[2024-07-05 21:28:40.793][rbfeeder] Input format changed to BEAST, 12MHz clock
[2024-07-05 21:28:41.115][rbfeeder] [2024-07-05 21:28:41]  Connection established.
[2024-07-05 21:28:41.233][rbfeeder] [2024-07-05 21:28:41]  Connection with RadarBox24 server OK! Key accepted by server.
[2024-07-05 21:28:41.234][rbfeeder] [2024-07-05 21:28:41]  This is your station serial number: EXTRPIXXXX
[2024-07-05 21:28:41.244][rbfeeder] [2024-07-05 21:28:41]  Client type: Raspberry Pi
[2024-07-05 21:28:41.396][rbfeeder] Beast-format results connection with 127.0.0.1:32004: connection established
[2024-07-05 21:29:09.247][rbfeeder] Accepted Beast-format results connection from ::ffff:172.19.0.6:46392
[2024-07-05 21:29:41.208][rbfeeder] Receiver: connected   297.3 msg/s received       61.2 msg/s processed (21%)
[2024-07-05 21:29:41.208][rbfeeder] Server:   ready         0.0 kB/s from server      0.4 kB/s to server
[2024-07-05 21:29:41.208][rbfeeder] Results:  12.9 positions/minute
[2024-07-05 21:29:41.208][rbfeeder] Aircraft: 1 of 13 Mode S, 16 of 26 ADS-B used
[2024-07-05 21:33:20.186][stats] Packets sent in past 5 minutes: 14148, total packets since container start: 1933
[2024-07-05 21:33:35.368][watchdog] [WARNING] No packets received from readsb:30005. Restarting rbfeeder binary
readsb container log:
Code: [Select]
[readsb]2024/07/05 21:03:15 Beast TCP output: Receive Error: Connection reset by peer: 172.19.0.9 port 60416 (fd 15, SendQ 0, RecvQ 0)
[readsb] 2024/07/05 21:08:20 Beast TCP output: Receive Error: Connection reset by peer: 172.19.0.9 port 44998 (fd 15, SendQ 0, RecvQ 0)
[readsb] 2024/07/05 21:13:24 Beast TCP output: Receive Error: Connection reset by peer: 172.19.0.9 port 44246 (fd 15, SendQ 0, RecvQ 0)
[readsb] 2024/07/05 21:18:29 Beast TCP output: Receive Error: Connection reset by peer: 172.19.0.9 port 39284 (fd 15, SendQ 0, RecvQ 0)
[readsb] 2024/07/05 21:23:33 Beast TCP output: Receive Error: Connection reset by peer: 172.19.0.9 port 58148 (fd 15, SendQ 0, RecvQ 0)
[readsb] 2024/07/05 21:28:38 Beast TCP output: Receive Error: Connection reset by peer: 172.19.0.9 port 52624 (fd 15, SendQ 0, RecvQ 0)
[readsb] 2024/07/05 21:33:42 Beast TCP output: Receive Error: Connection reset by peer: 172.19.0.9 port 35636 (fd 15, SendQ 0, RecvQ 0)
All my other feeders (PiAware, FR24 etc.) are working fine btw.
Thank you in advance.
« Last Edit: July 05, 2024, 08:04:47 PM by Randstad »
  • CYYZ - Toronto
Re: Constantly restarting rbfeeder binary
« Reply #1 on: July 06, 2024, 12:43:50 AM »
(1) Reboot Pi and check again
(2) Are you using package install or docker?
(3) Which image you have written to your microSD card?
Randstad
« Reply #2 on: July 06, 2024, 01:56:40 AM »
Thanks for your reply.
(1) I have an Intel NUC (rbfeeder thinks it's a RPi), I tried rebooting;
(2) Docker (docker compose in Portainer);
(3) Ubuntu 22.04 on SSD.
Before updating/redeploying the docker container, it used to work fine.
« Last Edit: July 06, 2024, 02:04:35 AM by Randstad »
  • CYYZ - Toronto
  • CYYZ - Toronto
« Reply #5 on: July 06, 2024, 05:02:14 AM »
Try this:
https://github.com/sdr-enthusiasts/
https://github.com/sdr-enthusiasts/docker-radarbox
That's the one I'm running.
Bad luck.
As far as I know, this one is the only one providing Radarbox24 amd64 in Docker
Randstad
« Reply #6 on: July 07, 2024, 05:15:05 PM »
Try this:
Bad luck.
Found a solution. The watchdog feature was introduced recently and is causing the problem.
Reverted back to build 625 (that doesn't have watchdog) and everything is working again. :)
  • CYYZ - Toronto
« Reply #7 on: July 07, 2024, 09:23:59 PM »
Glad to know you found the solution. :)
Thank you for posting the solution here. It will help other members who face this problem.
