Author Topic: Station showing Yellow instead of Green  (Read 27129 times)
Re: Station showing Yellow instead of Green
« Reply #15 on: July 16, 2024, 01:44:57 PM »
I note the red and yellow data blocks are now showing all green but although my station is showing aircraft on the page I am showing as offline for one hour
MLAT is showing as active but keeps changing from 30/40 stations synced to 0 stations synced https://www.radarbox.com/stations/EXTRPI565683
Now I have 55 stations synced but no aircraft showing ???
  • CYYZ - Toronto
« Reply #16 on: July 20, 2024, 12:11:42 AM »
My station is currently showinhg OK (see attached screenshot), but no gauratee. It keeps on changing to lot of red or yellow, stays like that for some period, then return to normal
https://www.radarbox.com/stations/EXTRPI000008
n7nat
« Reply #17 on: August 03, 2024, 09:05:45 PM »
I'm showing as many yellow blocks as green blocks and my flight aware station says they are there over my head. I think they have their deviation meter set too high.
highchain
« Reply #18 on: August 04, 2024, 12:06:18 PM »
I guess the problem at the server end is back. Showing lots of yellow on my stations.....
Station: EXTRPI603573
Vinnant CC1090/9-PSE
30 cm HDF 400 cable
uputronics prefiltered amp powered via USB cable
three meters HDF 400 cable
sysmocon cavity filter
10 cm HDF 400 cable
ADSBExchange usb stick (blue)
via USB-Kabel attached to a raspi 4 powered via POE hat-pack.
« Reply #19 on: August 04, 2024, 01:39:53 PM »
Nothing has changed as far as I am aware over the last 3 weeks since the issue was first noted.  The good news is that aircraft are still showing even if the various scripts appear to eb u/s
« Last Edit: August 04, 2024, 02:17:29 PM by Runway 31 »
« Reply #20 on: August 04, 2024, 04:28:15 PM »
Ha!! The yellow blocks have all turned green!
