Author Topic: Station showing Yellow instead of Green  (Read 27062 times)
Mum-O-Killowe
« on: July 06, 2024, 02:29:06 PM »
  Hi.   New user here.  I'm running AirNav RadarBox 6.02.003 on Windows.
 My station is EXTSHA197879.   Why does it show as "No Data" when I can clearly load the main page and see that my station is listed as the source?  Also, is there any way to get the planes and their info to display larger in ANRB?  The Station display is great , local is pretty poor.
Thanks,
Mum-O-Killowe
« Last Edit: July 06, 2024, 02:31:03 PM by Mum-O-Killowe »
Re: Station showing Yellow instead of Green
« Reply #1 on: July 06, 2024, 05:21:02 PM »
It will be an issue at the server end, once fixed it should turn green
As you can see on the link you are displaying aircraft on your station page https://www.radarbox.com/stations/EXTSHA197879 so everything ok at your end
Mum-O-Killowe
« Reply #2 on: July 06, 2024, 07:10:30 PM »
  Thanks Boss.
« Reply #3 on: July 06, 2024, 09:05:00 PM »
No problem Mum, my Pi is showing as offline for 2 hours but showing aircraft
darkskies74
  • AOR 8000. Station EXTSHA196235
« Reply #4 on: July 07, 2024, 03:52:20 PM »
Not just me then. Had the same issue for a couple of days, not that I've been uploading much this last few weeks. Hope it gets sorted soon. Cheers!
Was 32 NM SSW of YPPH.......where the sun shines.
Previously 31NM NNW of EGCC....where it didn't shine!
Now back near EGCC, Oh, how I miss the sun!!!
« Reply #5 on: July 07, 2024, 04:24:23 PM »
I have advised Airnav, wouldnt expect it to be sorted until at least tomorrow
darkskies74
« Reply #6 on: July 07, 2024, 04:43:20 PM »
Thanks Alan!
Randstad
« Reply #7 on: July 08, 2024, 03:20:20 PM »
All feeds are currently showing a yellow no-data bar since 12:00 UTC today.
« Reply #8 on: July 08, 2024, 08:31:40 PM »
Airnav are aware
« Reply #9 on: July 09, 2024, 09:30:16 AM »
Hi Mum
I see you are showing as offline for a couple of days, is that because you have switched off
I note in your original post you asked about the aircraft lables.  If you go to Map Options/Label Scale you have 4 size options. You can also use map options to detail what info you want to show on the label
obm
« Reply #10 on: July 12, 2024, 12:07:03 AM »
any idea / update on when this is going to be fixed? still showing lots of yellow and even some red on EXTRPI013282 though everything seems to be working fine (other feeders such as FlightAware) are still showing/working fine
« Reply #11 on: July 12, 2024, 11:09:28 AM »
No timescale for fixing, receivers are working ok as can bee seen from station pages as they show aircraft, the script for online/offline etc is needing fixed
VK5ATN
« Reply #12 on: July 15, 2024, 12:31:26 AM »
Thanks for the update - it's been a source of frustration for a few weeks now at various times.  Shared feed to other servers seem to be all ok - only the two radar box stations are painting the pretty colours.
« Reply #13 on: July 15, 2024, 04:06:14 PM »
Report your frustration to [email protected]
VK5ATN
« Reply #14 on: July 16, 2024, 05:23:32 AM »
All looking good as of this moment.  Thanks to all concerned.
TN
