rtlsdr: error opening the RTLSDR device: Device or resource busy
Started by ea5xq, December 25, 2024, 06:09:44 PM
ea5xq
I have installed rbfeeder and works fine. I added fr24feed and adbsexchange and only if teh Raspberry Pi (3b+) reboot rbfeeder faces problems to access the SDR (radarbox original), I have to stop rbfeed, fr24 and adsbsexchange, switch off/on the SDR and starts only rbfeeder and thereafter the rest. It seems that a process is taking the control of the device before Rbfeeder. How could I control it? thanks
     Active: active (running) since Wed 2024-12-25 19:01:39 CET; 9s ago
    Process: 22121 ExecStartPre=/bin/mkdir /var/run/rbfeeder (code=exited, status=1/FAILURE)
    Process: 22122 ExecStartPre=/bin/chown rbfeeder:rbfeeder /var/run/rbfeeder (code=exited, status=0/SUCCESS)
    Process: 22123 ExecStartPre=/bin/touch /var/log/rbfeeder.log (code=exited, status=0/SUCCESS)
    Process: 22124 ExecStartPre=/bin/chown rbfeeder:rbfeeder /var/log/rbfeeder.log (code=exited, status=0/SUCCESS)
    Process: 22125 ExecStartPre=/bin/chown rbfeeder:rbfeeder /etc/rbfeeder.ini (code=exited, status=0/SUCCESS)
    Process: 22126 ExecStartPre=/bin/setfacl -m u:www-data:rwx /etc/rbfeeder.ini (code=exited, status=0/SUCCESS)
   Main PID: 22127 (rbfeeder)
      Tasks: 10 (limit: 1595)
        CPU: 698ms
             ├─22127 /usr/bin/rbfeeder
             └─22136 /usr/bin/python3.9 /usr/bin/mlat-client --input-type dump1090 --input-connect 127.0.0.1:32457 --server ml>
Dec 25 19:01:42 RaspiNOAA rbfeeder[22168]: usb_claim_interface error -6
Dec 25 19:01:42 RaspiNOAA rbfeeder[22168]: rtlsdr: error opening the RTLSDR device: Device or resource busy
Dec 25 19:01:45 RaspiNOAA rbfeeder[22218]: Wed Dec 25 19:01:45 2024 CET  dump1090-rb 1.0.10 starting up.
Dec 25 19:01:45 RaspiNOAA rbfeeder[22218]: rtlsdr: using device #0: Generic RTL2832U OEM (AIRNAV, ADSB_1090, SN 00000010)
Dec 25 19:01:45 RaspiNOAA rbfeeder[22218]: usb_claim_interface error -6
Dec 25 19:01:45 RaspiNOAA rbfeeder[22218]: rtlsdr: error opening the RTLSDR device: Device or resource busy
Dec 25 19:01:48 RaspiNOAA rbfeeder[22257]: Wed Dec 25 19:01:48 2024 CET  dump1090-rb 1.0.10 starting up.
Dec 25 19:01:48 RaspiNOAA rbfeeder[22257]: rtlsdr: using device #0: Generic RTL2832U OEM (AIRNAV, ADSB_1090, SN 00000010)
Dec 25 19:01:48 RaspiNOAA rbfeeder[22257]: usb_claim_interface error -6
Dec 25 19:01:48 RaspiNOAA rbfeeder[22257]: rtlsdr: error opening the RTLSDR device: Device or resource busy
I would suggest that RB feeder is trying to uses its internal 1090 but as the stick is already in use with the FR24 1090 is cannot connect.  Can you post your ini file with your details redacted
ea5xq
here is the rbfeeder.ini
[client]
network_mode=false
sn=EXTRPI657091
#device=00000010
lat=39.917340000000003
lon=-0.0071050000000000002
alt=13
[network]
mode=beast
external_port=30005
external_host=127.0.0.1
[mlat]
autostart_mlat=true
[dump978]
dump978_enabled=false
And the fr24feed.ini
receiver="avr-tcp"
host="127.0.0.1:30002"
bs="no"
raw="no"
mlat="yes"
mlat-without-gps="yes"
Under Client, change network_mode=false to network_mode=true
Had a look at EXTRPI657091 and you are showing aircraft
ea5xq
Thanks!, it worked like a charm, now I am able to feed three aggregators
bvb40170
Hi!   I'm having the same problem.  I've changed the .ini under client to true (from false).
This didn't change anything and I'm still offline.  My station is EXTRPI025073
Help, please!
Please post output of following command:
pgrep dump -l
