SettingHome station Home staion Data
Started by jasper37, July 11, 2008, 12:36:52 PM
jasper37
tried to input my home station data but for some reason it wont keep the setting
any help re this plz
thanks
Spaice
Are you wishing to set your location using lon/lat coordinates or your nearest town.  If you want to set your exact location then you need to use lat/lon coordinates in decimal format (55.1234 -1.1234).  You can get the lat/lon from google earth but make sure you select decimal in settings.
jasper37
yep....i type my settings in the lat/lon coordinates  box in decimal format for my exact location
close the box and it hasnt kept the setting i entered when i go back into the
Those details are saved to your registry. If they are not saving either you have limited rights on your machine (you are not admin) or you have some other software which is "locking" down your settings.
Is this by chance a work machine?
jasper37
hi support..............this pc is my own vista is the op sys never really had this type of problem b4...... any other check i can do re this??
thx
Are you using the latest version 1.5 (RadarBox 2008) not 2007?
jasper37
yep latest ver,,,,,,,,,since it was available
jasper37
hmm............just looked on my laptop which also has radbox ver 1.5 on it
running xp not vista
and within preferences>>>home sation data tab there is a apply...ok..cancel and help tab at the bottom of the box in  win xp
these are not displayed on my main pc running vista
is this a bug in vista??????
thx
Change your display settings from from large fonts to small fonts in Vista and you should be able to see it.
jasper37
ok thx support.............all sorted now
thanks
