Author Topic: How to disable LOADING of "Network Flights" in ANRB  (Read 475 times)
airdata
    • Airdata
« on: January 16, 2025, 01:27:33 AM »
Hi all
Is there a way to disable network flight upon startup of radarbox software?  The option is ticked by default upon program loading and it uses a lot of PC resource.  I'm using version 6.02.003.
Mark
Under the flight path, 5NM from runway 23L threshold at Auckland (NZAA), New Zealand.
Re: How to disable LOADING of "Network Flights" in ANRB
« Reply #1 on: January 16, 2025, 01:24:55 PM »
Just untick Get Flights from the Radarbox network while on the network tab and ensure you come out of the program by using File/Exit and any changes made to the set up will stick.  Clicking on the X top right to exit the program does not save any changes you made to the set up during the session
