Author Topic: Total Ancient Newbie - Flightstick  (Read 229 times)
Jamie P
« on: January 29, 2025, 03:43:49 PM »
Total Ancient Newbie, so go easy on me.
Purchased yesterday via Amazon, a Green Flight Stick USB and 1090Mhz antenna.
No idea if it was  what i was hoping :)
I was hoping i could plug the USB into my Windows 10 PC, stick the antenna somewhere in the air, and not only see Aircraft but here their radio transmission's as well???
Did i get the right thing?
Jamie
Embarrassingly a former Avionics Engineer 40 years ago
Re: Total Ancient Newbie - Flightstick
« Reply #1 on: January 29, 2025, 06:34:37 PM »
Hi Jamie
To see what you are picking up you will need to dowmload and install the Radarbox software from here
https://www.airnavsystems.com/download/ANRB/ANRB60003Setup.exe
You will also need to download and install the drivers for the stick from here https://www.airnavsystems.com/Download/ANRB/Drivers/microRadarbox-Drivers-20150411.exe
You will not be able to hear anything using the stick as it is ADSB only
