Filters dont work as expected
Started by Capecod, June 09, 2026, 02:49:47 PM
Capecod
Hello there, i'am a feeder (Debian 13) with business account. On the website, on Firefox (151.0.3) but it's th same on Edge. I set up two filters 1/LFRS (dep/arr) and 2/AFR Cie. When both filters are activated, map is empty, no flights at all. When AFR is activated AFR flights are on screen. When LFRS is activated only, no flights are on screen. When filters are desactived all world flights are on screen. Is someone else experience this ? Rgds
Is this what you are looking for, only LFRS flight asked for
Capecod
Yes but no, i want to see all flights to/from LFRS and all AF flights. i try other airport in filter, but there is no planes at all. Only filter airlines Cie work.....
Rgds,
OK just filtered AFR and LFRS and showing the attached
Capecod
#4
Ok, here are the screenshots !!
Sceen 1/ AFR
Screen 2/ LFRS and AFR
Screen 3/ LFRS
Just did it again and working OK for me
Do this
Click on Filters, click on Airline, type in AFR where it states Filter Airline
Click on Airport, click on Origin and type in LFRS and when the airport shows click on it
Click on destination and type in LFRS and when the airport shows click on it
Click on the plus symbol and that should be it showing all AFR flights in the air to and from LFRS
Capecod
#6
Hello Runway 31, this is exactly what i do !!!
I want to have a filter with all AFR worldwide AND all flights from/to LFRS regardless of the airline, but in the same time !
#7
Well if you cant get it going I suggest you contact support and ask for assistance
Its working for me per the attached
Capecod
No idea how you get that but I received clarification from Airnav
Set AFR as the airline
On the airport tab set LFRS as origin and leave destination blank ckick on the green + bar.  Now leave origin blank and LFRS as destination the click the green plus bar
You should then see it set as LFRS to Anywhere and Anywhere to LFRS
You should then only see AFR flights to and from LFRS
Capecod
#10
Quote from: Runway 31 on June 11, 2026, 12:44:39 PM
No idea how you get that => Screenshot from my FR24 account
On the airport tab set LFRS as origin and leave destination blank ckick on the green + bar.  Now leave origin blank and LFRS as destination the click the green plus bar => that's OK !!!
You should then see it set as LFRS to Anywhere and Anywhere to LFRS => Correct !!
You should then only see AFR flights to and from LFRS => i dont want that !!, i want to see all AF flight around the word !! so one filter for to/from LFRS AND ONE FILTER AF flights around the world on the same time on the same map !!
Screen one => LFRS to/from only => OK
Screen two => AFR only => OK
Screen three => LFRS + AFR together => NOT OK !!!
Thank's to take time with that ;-))
Capecod
#11
You cannot get all AFR flights and all LFRS flight at the same time.  You get either all AFR flights or all LFRS flights not them both combined on the same screen
I suggest  that you ask Airnav for an addition feature in a future version to be able to combine filters
Capecod
Hello Alan, i have no doubt that Airnav Radar can do it, just like fr24 does, for example...
Anyway, thank you for your patience, your time and your understanding !!
Sylvain
They will be able to do it, if its asked for.  If nobody asks for it I doubt it will be provided
support@airnavradar would be happy to receive your feedback and forward to developers for consideration
