Diablo 4 S15 Patch 3.2.3 Arrives October 14! A Look at the Update Contents!
Started by salisy, Today at 01:50:13 AM
salisy
Diablo 4 Season 15 "Legacy of Hell" Patch 3.2.3 is scheduled to arrive on October 14. This update is not a major content drop; instead, it targets several key friction points in Season 15, mainly the seasonal quest lockout, Horadric Cube affix reroll issues, and certain boss fight and loot pickup problems. For players planning their Diablo 4 items and gold routes, the patch should make progression more stable after October 14.
Seasonal Questline Fix
Season 15's seasonal questline revolves around the three Prime Evil echoes. Players need to collect Splinters of Evil and advance War Plan reputation to eventually unlock Prime Evil Powers. A serious issue existed before this patch: if a player used a Splinter of Evil before finishing the seasonal questline, the character could become unable to continue the questline, effectively locking the Prime Evil Powers.
Patch 3.2.3 fixes this logic hole and prevents early Splinter use from triggering the quest lock again. Note that the fix will not automatically reset progress for characters already affected. If a character is already stuck, the recommended workaround is to create a new character under the same realm and mode conditions, complete the seasonal questline on that character, and then all characters in that realm should unlock the corresponding rewards.
Horadric Cube Affix Reroll Fix
The Horadric Cube is a core crafting tool in Season 15, but some affixes could not be rerolled properly before this patch. That made it difficult to continue optimizing otherwise strong gear. The affected affixes included Impairment Reduction, Barrier Generation, Healing bonuses, and Critical Strike Damage.
After the fix, players can use the corresponding Tuning Prisms to replace these affixes. This matters a lot for Diablo 4 items progression: gear that previously had to be abandoned because of a stuck affix can now be salvaged through rerolling. High-frequency affixes such as Critical Strike Damage and Barrier Generation should become easier to manage, improving both gear filtering and reroll efficiency.
Community testing suggests the fix may primarily apply to base item affixes, while some Seal affixes could still behave abnormally. If you plan to do heavy rerolling after the update, test with low-value items first to avoid wasting materials. If you need a large number of items for testing, you can buy Diablo 4 items you require from IGGM—it's both convenient and affordable!
Boss Fight and Loot Pickup Fixes
Baal is an important source of Mythic Uniques and high-value gear in Season 15. Before Patch 3.2.3, Tyrael's model could sometimes block Baal's drops after the fight, making loot pickup difficult, especially for controller players. The patch fixes this pickup issue, so clearing loot after Baal kills should be smoother.
The update also fixes two boss encounter issues: the Sandstone Golem in the Horadric Library may no longer respawn after a player dies in combat, and the Countess in the Forgotten Tower could walk through the fog wall and break the encounter flow. These fixes will not directly change drop rates, but they should reduce repeated runs and interrupted fights, making Diablo 4 items farming more consistent. If you need a large number of items for testing, you can purchase the Diablo 4 items you require from IGGM—it's both convenient and affordable!
Necromancer Class Quest Optimization
The Necromancer class quest "Call of the Underworld" previously had an issue where some enemies did not drop Unbroken Bones, causing unstable quest progress. Patch 3.2.3 fixes this drop problem, so Necromancer players should complete the quest more efficiently. The saved time can be redirected toward Lucid Nightmares, Hell Incursions, and Nightmare Dungeons.
Diablo 4 Progression Tips
Patch 3.2.3 does not add new gold-farming mechanics, but by fixing the quest lock, reroll bugs, and boss pickup issues, it indirectly improves Diablo 4 gold and gear progression efficiency. After the update, check your seasonal questline status first to avoid investing more resources into a locked character. Use Tuning Prisms to rescue strong gear bases and reduce the gold spent on repeatedly farming new bases. With Baal farming more reliable, selling high-value Ancestral Legendaries and Uniques remains a common gold source.
Overall, Patch 3.2.3 is a practical quality-of-life update. It does not change the core Season 15 loop, but it resolves several issues that directly affected Diablo 4 items progression and farming efficiency. After the October 14 update, it is worth checking your questline status and reroll behavior before deciding how to allocate future farming and crafting resources.
