Demo Mode/V1.6
Started by JRS98, July 16, 2008, 03:04:59 AM
JRS98
Well I have been messing with the demo mode for a few days now. I really like the look of the maps but but the program is very slow. Everything I drag or click on has a delay. Sometimes it takes 5 seconds to do something. Unchecking the share data box didn't work either. This is a problem on both of my computers. Is the new version (V1.6) going to be easier to deal with? Like I said I really like the maps and the features but it's just frustrating dealing with the slowness.
Jon
What is your computer spec?
The demo mode won't be using the share data anyway. It should only just be playing back some saved data.
Quote from: JRS98 on July 16, 2008, 03:04:59 AM
Jon
Most odd.  As support said, there isn't any processing going on during the demo so there's no reason why RadarBox should be running as slowly as you say.  As it's happening on both your PC's, then there must be something you have installed on both that is causing the problem.
When you look at the task manager (Ctrl Alt Del), what's the CPU loading with and without RB running?
JRS98
Yeah the shared data doesn't matter here you're right. My PC is 2.8 GHZ and 256 RAM. The laptop is 1.83 and 1GB RAM. I realize the PC ram is low. The cpu usage on the laptop when running firefox and a program for my scanner is 3% to 12% then when I run the radarbox is goes up to 50% and even higher. The PC is pretty much the same way. Thanks again.
Jon
Roadrunner
Can anyone tell me how I can see the v1.6 demo mode?
#5
It's just the same as the V1.5 demo - but you have to have the V1.6 beta software to see it :-)
JRS98 doesn't have a RadarBox, so his only option is to watch the demo mode on the current V1.5 download version.
