Vista 64bit Driver
Started by Steve R, July 16, 2008, 07:01:15 PM
Steve R
Hi All,
Can anyone tell me if there is a driver available for the RadarBox which runs on Windows Vista 64bit?
I have tried installing the driver that comes supplied on the Cd-Rom, however I get a message saying that "The Driver is not digitally signed", I worked around this using the fix to disable the Windows Driver Signing, then I get the following error saying "Windows is unable to install the selected driver".
Does anyone have any recommendations or even better a 64bit Driver that will help?
Steve R
nortonbeak
Steve R
Your right Nortonbeak,
However I dont have the link to the drivers that were pmmed to the original question poster.
Also as I said in my post , I've tried the 'Windows Fix' to disable the driver signing but this is no good.
Steve R
The drivers are FTDI Drivers, and they are same included in the 2008 version.
What windows fix did you do? as Other customer using the fix have installed it fine.
