Author Topic: Problem In Radar Location  (Read 14223 times)
Junio Gracielo
« on: December 25, 2017, 11:39:16 PM »
I would like to know how to solve this. I am from Serra-ES (Brazil) and the location is from São Paulo.
My location this station correct this is: https://www.google.com.br/maps/@-20.2202041,-40.2808557,18z
Thanks for solution!
G-CONC
Re: Problem In Radar Location
« Reply #1 on: December 26, 2017, 04:54:49 AM »
Hi Junio. It seems that the radar box is set to the wrong location. After you have opened the RadarBox 24 program and completed the sign-in details, you will have a split screen with map and aircraft details. At the top left side in the menu bar click the file tab, one from the bottom will be Preferences click here, a tab will open, look for Home Station Data click here. You can choose to Auto detect my location or next one down select your location from the drop down list. This should put your home location in the correct place on the map.
« Reply #2 on: December 26, 2017, 08:10:53 AM »
Hi Junio.
I have edited your location for you and should be OK for you now.  I presume that you have not used the correct location details in Preferences/Home Station data.
« Last Edit: December 26, 2017, 08:17:44 AM by Runway 31 »
Junio Gracielo
« Reply #3 on: December 27, 2017, 09:10:20 PM »
Thanks!
Fanjet500
« Reply #4 on: January 07, 2018, 11:36:00 AM »
Hallo all,
My Radar location PGANRB110545 is also messed up since a while. My settings should be o.k. 47.6172/8.2685, Kuessaberg Ettikon Germany. It was o.k. for a long time and i do not understand how it came. Could please someone fix it?  Thank you.
Rolf
2 Airnav Radarbox installations
2 Antenna switch boxes
1 WiMo GP-1090
1 FLU-SR/Y13
2 ThieCom SkySearcher directional antennas
2 Standard Airnav Radarbox antennas
« Reply #5 on: January 07, 2018, 01:59:16 PM »
That's you sorted Fanjet
Fanjet500
« Reply #6 on: January 07, 2018, 04:58:35 PM »
Thank You
Wow, now it is also listed in the correct country.
Greetings Rolf
1 WiMo GP-1090
1 FLU-SR/Y13
rsgomes
« Reply #7 on: April 08, 2018, 11:46:26 PM »
Hi there,
My location is also wrong. My location is Loulé (near Faro[LPFR]) and the coordinates are 37.1593, -8.0817 and on RB24 shows that my location is Lisbon. How I change the location to the correct? Regards.
« Reply #8 on: April 09, 2018, 07:23:37 AM »
Now changed
rsgomes
« Reply #9 on: April 09, 2018, 12:45:16 PM »
Thanks Alan! Best regards.
Ricardo Gomes
