Aircraft not tracking
Started by John Racars, July 15, 2007, 04:44:40 PM
John Racars
Hi All,
There is an other thing I do not understand. For exemple: All BAW B737 in series G-DOC. and all KLM MD-11, B737-3 and B737-4, are not showed on the map while they are listed in the Radarbox interface.
Is this a well known problem?
Thank you in advance for any help or clou...
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
Quote from: John Racars on July 15, 2007, 04:44:40 PM
Hi All,
I presume that you are referring to no globe and "NA" in the aircraft list.
Not all aircraft have the more modern full ADS-B equipment fit which gives position and allows them to be shown on the map.   Other aircraft might have the equipment, but do not transmit the position - military aircraft and chartered executive jets for example
John Racars
Quote from: Allocator on July 15, 2007, 05:07:11 PMI presume that you are referring to no globe and "NA" in the aircraft list.
Yes Sir! That is correct.
In all the time I am using this system there was one big surprise yesterday:
there was G-DOCA on the map while, I have described this before, I have never seen one of the BAW G-DOC. series and I know that they are flying to / from / over the Netherlands the whole day.....
13 NM East of EHAM
ANRB:
John,
From my records of ADS-B traffic using the SBS-1, G-DOCA is the only aircraft in the G-DOC* series that has given me position information.  Maybe the aircraft has been in for servicing and has had the new kit fitted.  We can hope that the rest will follow!
All the best
Gary
John Racars
Quote from: Allocator on July 15, 2007, 06:13:26 PMWe can hope that the rest will follow!
Hi Gary,
And I do hope so! Today I catch an other I did never see until sofar! It was one of the BAW G-BUS* series. G-BUSF apears on the map this afternoon.
13 NM East of EHAM
ANRB:
#5
Yes,  G-BUSF is once again the only one in the G-BUS* series that I have too with position - most odd!
This again is from my SBS-1 Basestation Reporter (database reader).  Unfortunately, the AirNav database has not matured to the point where it gives historical data with this detail.
John Racars
Quote from: Allocator on July 15, 2007, 06:52:06 PM
BTW Gary,
What do you see if you are centre to "EHAM"? I am verry curious to know...
13 NM East of EHAM
ANRB:
Two screenshot centered on EHAM
