Author Topic: Data interface problem  (Read 3727 times)
viw
« on: August 05, 2008, 09:43:09 PM »
had to re-install my software and mixed up something.
The data interface doesn't appear automatically - the screen is showing the full map and I  have to activate it  manually with the "Interface show/hide" button.
How do I change this to be there automatically upon starting the RB?
Thanks for your help.
rgds.
viw
Re: Data interface problem
« Reply #1 on: August 05, 2008, 10:03:16 PM »
It should rememeber it, Go to Window and Record Desktop and then close down RadarBox and then reopen it.
Also confirm you are using RadarBox 2008 (1.5 version)?
viw
« Reply #2 on: August 06, 2008, 03:22:15 PM »
Hi Support
Your suggest worked fine - it's OK again
(Yes I'm using 1.5 Version)
Thank you!!
