Cost of Airborne ADS-B equipment
Started by AirNav Development, August 06, 2008, 02:32:44 AM
A question to our users: does anyone know the price of an ADS-B equipment to be installed on a general aviation aircraft like a Cessna 172? What models are available?
Any help appreciated.
bailey_uk
Ive often wondered that! Im gona fit one to my car if its affordable haha! So I know where the Missus is!
CAM
Cumulus
#3
The three I know of are:-
Trig Avionics TT31
£1600 (+VAT)
http://www.trig-avionics.com/products.html
Garmin GTX330
£2300 (+VAT)
https://buy.garmin.com/shop/shop.do?pID=201
http://www.flyasg.co.uk/shop/gtx330.php
LX Avionics
TRT 800 Mode S transponder
http://www.lxavionics.co.uk/transponders.htm
Becker Avionics
BXP6403 Class 1 IFR
£2299
BXP6403 Class 2 VFR
£1975
http://www.transair.co.uk/Category.asp?SID=1&Category_ID=2673
Cheers,
Peter
Quote from: Cumulus on August 06, 2008, 03:56:14 PM
Trig Avionics TT31
£1600 (+VAT)
Garmin GTX330
£2300 (+VAT)
LX Avionics
Becker Avionics
BXP6403 Class 1 IFR
£2299
BXP6403 Class 2 VFR
£1975
I don't think any of these have integrated ADS-B, which was the original question.
Dave
Cumulus
#5
Dave,
Do they not all support ADS-B and only require the addition of a GPS input.
PTT31 Installation Manual
Quote5.5.10 GPS Position Input
The GPS position input is required to support ADS-B functionality. The GPS position input is an RS232 input to the transponder and is on the 12 way secondary connector. The ADS-B features are optional – no GPS is required for normal Mode S Elementary Surveillance.
The TT31 GPS input can recognise either the industry standard "Aviation" format or the NMEA 0183 format; the interface speed can be selected between 4800, 9600 and 19200 bps.
There is also an RS232 output on the 12 way connector for future expansion. This pin is unused and should be left unconnected.
TRT800
QuoteADS-B ready, supports Extended Squitter, connection
to GPS receiver with optional adapter cable
Becker BXP6403
QuoteThe BXP6403-1-(01) is a compact and lightweight
single block Mode-S transponder. It is certified according
to ETSO-2C112a and is suited for VFR and IFR
operations up to 50000 feet.
The transponder is equipped with extended squitter and
SI code function and it provides an interface to the central
aircraft data system. It allows ELS, supports EHS, as
well as ADS-B via extended squitter.
I think most light aircraft are now equiped with a GPS receiver with NMEA output.
Peter
Quote from: Cumulus on August 06, 2008, 05:15:03 PM
I'm not sure about the "most".
If that's true then I'm surprised at - out of all the light aircraft that now have a Mode S transponder - how few have seem to have their GPS hooked up to it ...
I still only need one hand to count the ADS-B-equipped spamcans I've picked up  :-)
Dave
