New Silhouettes
Started by RodBearden, August 19, 2008, 11:19:45 PM
Sounds good for me, I'll do it same way you did. As for me: no TACT silhouette will be needed.
besty
Only problem I've just found was a GAF CL-60 showing full adsb flying up the coast and showing details of an USAF F15 because of the reg, the flight number and logo were correct but showed as various F15 aircraft.
something to think about, I've gone ... for reg and type for the aicraft instead.
Stuart
Had a look in the d/b and all GAF CL60's are marked as such and with "Tactical Code - Various CL60 Aircraft" as AT they use a different hex on each mission.
The USAF F-15 have even been noted using Russian hex code allocations.  They are all marked as "Tactical Code - Various F15 Aircraft" for same reason
Hi Rod, while preparing a posting for the database updater I found the Pitts Special S-1-11X (PTS1) AC without a Photo-Silhouette.
Warning! It will be hard to find a suitable Picture of this AC Tape for a Photo Silhouette. But if you can make it many thanks!!
I've done the PTS1 already, but I forgot to post it!
besty
If the reg shows as a 'tactical' AR the details show on your log as a F15 of the USAF, the logo may be correct from the flight ID but the type will show as a F15.
Stuart
sorry it's off this topic will try the databse one in future
Hi Rod, just got a Cessna 207 Skywagon on my Screen. Unfortunately without one of your beautiful Photo Silhouettes. (http://www.planepictures.net/netsearch4.cgi?srch=D-EBSD&srng=2&stype=reg)
Thanks ahead!
Here's the C207 silhouette.
Here's one for the VL-3
Aerotower
Hello Rod,
Do you know someone who makes traditional silhouettes for CRJX and the VL3?
I'm afraid not - we don't have a maker of the standard silhouettes after Ian left us :-(
#131
The newly-released database has shown up the need for two photo-silhouettes that I hadn't done - I'm sure more will pop up with time.
So here are an FA10 and an AT75
EDIT I had already done the FA10, - odd that it hadn't shown up first time round. I prefer my old one, but I'll leave this here in case anyone prefers this, but I won't include this version in the in the next zip.
anorak
Has anyone a silhouette for a Piston Provost (PPRO) please?
Dave.
Dave. Exmoor, North Devon.
ACW367
Airnav certainly don't :(
anorak
