Author Topic: New Silhouettes  (Read 823256 times)
Re: New Silhouettes
« Reply #90 on: September 03, 2010, 01:26:45 PM »
C10T (CESSNA     P210 (turbine) ) not very common here, but from time to time
Yes, Turbine 210s are like hen's teeth, AFAIK there are fewer than 10 worldwide, although at least two of those are in Europe.
Re: New Silhouettes
« Reply #91 on: September 03, 2010, 02:04:08 PM »
I don't seem to have a silhouette for the AS350B or I have inadvertantly deleted it (more likely). Any chance of a redo?
Re: New Silhouettes
« Reply #92 on: September 03, 2010, 03:51:22 PM »
Eurocopter AS-350 B, ICAO Designator: AS50
    • Rod's RadarBox Downloads
Re: New Silhouettes
« Reply #93 on: September 03, 2010, 08:27:58 PM »
Here come more "silhouettes":
C10T
KL07
B407
B105
More follow...
Re: New Silhouettes
« Reply #94 on: September 03, 2010, 08:32:02 PM »
The rest:
EN28
RV4
Re: New Silhouettes
« Reply #95 on: September 12, 2010, 05:12:35 PM »
By special request:
SB29 Saab 29 Tunnen
Re: New Silhouettes
« Reply #96 on: September 12, 2010, 05:33:56 PM »
SB29 Saab 29 Tunnen
I think you mean Tunnan, although that wasn't an official name, given that it's Swedish for "barrel" !
Re: New Silhouettes
« Reply #97 on: September 12, 2010, 06:08:47 PM »
Must learn to trype better ;-)
anorak
Re: New Silhouettes
« Reply #98 on: September 12, 2010, 09:25:39 PM »
Thanks Rod, tis in my flowder,  Dave.
Dave. Exmoor, North Devon.
Re: New Silhouettes
« Reply #99 on: October 15, 2010, 05:17:26 PM »
Now that we're getting an aircraft code of Test for various Boeings and Airbuses, I thought folk might like something to fill the gaps in the silhouettes column. Take your choice. Rename Test-1.bmp to Test.bmp if you want to use that.
EDIT - I just remembered that the "standard" silhouettes are narrower than the "photo" ones that I normally do, so I've resized it so that it doesn't stick out from the others.
« Last Edit: October 15, 2010, 08:40:38 PM by RodBearden »
Re: New Silhouettes
« Reply #100 on: December 15, 2010, 09:13:14 PM »
Here's a zip with 23 "silhouettes" including the ones posted here since the previous zip, plus a few extras including the sample here.
« Last Edit: December 15, 2010, 09:21:29 PM by RodBearden »
Re: New Silhouettes
« Reply #101 on: December 22, 2010, 12:45:32 PM »
I've been using these "silhouettes" for a while and find them fairly useful. There's one for the photo-style and one for the smaller conventional style.
Take your pick and copy/rename them for other examples of wrong type codes which currently appear despite the best efforts of the database updaters. Examples include A380, B77F and BKC3.
Re: New Silhouettes
« Reply #102 on: January 05, 2011, 06:33:20 PM »
Hi Rod, it would be great, if could make a photo silhouette for the Aerospatiale    SA-365C Dauphin 2 (S65C), because PHOENIX Hannover/Hildesheim uses one of these for their "surveillance flights"  along the A2 -which is very close to my home position-
EDIT: A link to some Pictures: http://www.planepictures.net/netsearch4.cgi?stype=reg&srng=1&srch=D-HOPE
Thanks for the "wrong code" "silhouettes" they're indeed very useful By< the way: Another very common is B77F instead of the correct B77L
About the TEST "silhouette": I just considered to ask you about doing one by using some "green Aircraft" in one Picture. Now I decided to use the yellow/red one but I will change the RED into Green or the yellow background into green. Have to see which combination looks better ;-)#
Thanks again!
« Last Edit: January 05, 2011, 06:36:54 PM by neroon79 »
Re: New Silhouettes
« Reply #103 on: January 06, 2011, 01:56:35 AM »
Hi Ingo
Thanks for that - here's the S65C and a green Wrong Code silhouette, though a lot of te "test" aircraft aren't actually green :-)
EDIT Oops - did a wrong Silhouette instead of a Test one - now rectified.
Hope you like them.
While I'm at it, here's another thai I've done recently, the R722
« Last Edit: January 06, 2011, 12:26:13 PM by RodBearden »
Re: New Silhouettes
« Reply #104 on: January 06, 2011, 06:58:20 AM »
Hi Rod!
Well, the "real" Test AC are usually not green, but the first flights of new Airbus "Birds" on their maiden flights are often green. Same is valid for the ferry flights  from tls to do the "paint-job" in xwf. Anyway, I like the green on yellow TEST icon more, because red on yellow is a kind of to intense/aggressive colour combination for my eys. ;-)
Another Request:
A Photo Silhouette for the Cessna 414 Chancellor (C414) would be great.
