New Silhouettes
Started by RodBearden, August 19, 2008, 11:19:45 PM
EGNXR
Already done. Didn't think to look for whit. I'm a long way off your 10mins to do one:-)
Cheers John (Fun trying though)
Based in Derby 5Nm NW of EGNX
EGNXR
Picked up 403362 G-BTDE Cessna 165 Airmaster do we have a silhouette for said beast?
Looked under the obvious C165, AIRM or is under a differant ICAO ID?
MTIA cheers John
IAN K
Hi John
If you go to the following website you can do a search for Cessna 165 Airmaster and it will give you a CMAS
http://www.icao.int/anb/ais/8643/index.cfm
EGNXR
Here's another instalment of the pictorial "silhouettes" that I use instead of Ian's (sorry, Ian!).
There may be one or two people who like these, so here they are, and there's a zip of all the silhouettes that I've done on Allocator's Utilities Download page at radarbox.gofreeserve.com/html/downloads.html.
As ever, the sample below is included in the zip.
IAN K
Zip file updated today
IAN K
malcdee2001
Is there a silhouette for Apache AH.1, type H64
Thanks, malc
IAN K
Yes it is in the zip, but have attached it again for you.
IAN K
Zip file updated today.
54901 - Jim
Here's a B193 silhouette ...
Jim
Oshkosh
KOSH - Oshkosh, Wisconsin USA
GreekSpy2001
Quote from: RodBearden on April 23, 2009, 08:53:45 PM
Is there a combined update available that adds to the file on Allocators webpage that is dated 23/4 ?
Graham
GreekSpy2001
Also just noted i this file the pictorial silhouette for B763 is a Jet Airways 777.
Apologies if this has been noted before.
Graham
#58
Graham - the 777 goof hasn't been noted before! I'll provide a replacement in the next update zip that I do, which will now be very soon!
Thanks!
Jim - thanks for the "silhouette" - I've got stuck on the Beech airliners because there isn't actually an ICAO code B193 - it should be B190 for all models of 1900's, but I looked in my database and saw so many B192 and B193 entries that I gave up!
54901 - Jim
Thanks for the info, Rod!
Jim
