New Silhouettes
Started by RodBearden, August 19, 2008, 11:19:45 PM
Carlos,
You may have used V4.03, here is the link the the install file: http://www.airnavsystems.com/download/ANRB/403/ANRB403Setup.exe
But it's possible that you won't get back 3D anyway, as google has withdrawn the 3D Plugin many month (or by now some years) ago.
CarlosAbreu
Hi Ingo
Thanks for info, I'll try that.
Have a nice weekend.
Brgds
CA
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Returning to photo-silhouettes, here are some more:
CH65 - AMD CH-65 Zodiac
J2 - Piper/Taylor J-2 Cub
LESP - Lancair ES-P
VTRA - Rans S-19 Venterra
And more:
JANU - Schempp-Hirth Janus BM, CM, CT
LS8 - Rolladen-Schneider LS-8T
P1 - Kawasaki P-1
Z37P - Zlin Z-37A Cmelak
Hi Rod,
Did you get the request on #882 ?
#890
Hi Rod,
Request 882 was about the AGUSTAWESTLAND AW-189 designator A189
https://en.wikipedia.org/wiki/AgustaWestland_AW189
I found it in my silhouettes folder
Sorry Ian - I had missed that, but thanks to Ingo for answering it!
A couple more:
C190 - Cessna 190
SU26 - Sukhoi Su-26
Rod/Ingo,
Thanks to both.
Four more:
MIMU - Bushby Midget Mustang
PICO - Procaer/General Avia F-15 Picchio/Delfin
SF23 - Schiebe SF-23 Sperling
U15 - Phoenix Air  S-15 Phoenix
silverjet102
Is it possible to have a standard version of the following please?
KC39 - Embraer KC-390
Cameron
Sorry Cameron, I can't help with standard silhouettes.
Her are two more photo versions:
PETR - Edra Petrel/Seastar
COZY - Rutan Cozy
CarlosAbreu
#896
Hi List
Any classic silhouette for Dova DV-1 Skylark (DV1) or I rename the D20 one to DV1 as they are similar  ?
Carlos
#897
Carlos,
The ICAO Designator D20 doesn't exist (anymore). If you were refering to DV20, that ICAO doens't exist (anymore) either.
The currently valid designator for the Dova DV-1 Skylark or Dova Skylark or Marsden Skylark is -as you already stated- DV1
The ICAO updates/changes the designators by the end of every month. Usually major updates are announced here on the forum.
DV20 still exists it is the ICOA type designator for the Diamond DA20
Personally I don't think they are very similar https://en.wikipedia.org/wiki/Dova_DV-1_Skylark  https://en.wikipedia.org/wiki/Diamond_DA20
Alan is right about the DV20.
Seebs that for me the ICAO DOC 8643 search has had some problems today morning, as it didn't delivered any result for designator DV20.
Thanks for the correction Alan.
