No directory Recorder
Started by f6gsg, August 22, 2008, 09:04:34 PM
f6gsg
Hi all,
i will try with the 2.0 the recording mode.
With RB, no problem, possibility to start recording and to play record files.
(but always no information - like red dot - that we are un recording or play mode..)
But when i want to examine files (for using with my RBTools) directly in
the recorder directory  (with explorer) NO DIRECTORY recorder !!!
(and in same time no directory satelitte and temp).
impossible with the "find function" to find *.rbl files !!!!
i'm using Vista pro, and i have verify when i open the windows
files in recorder play mode, that i have the right autorisations
to this directory. Because in thsi windows, i can look all directory in
Airnav Radarbox 2009....
is Only RB can look this directory ?
is somebody  have a idea ??
Patrick/F6GSG
Sorry if we haven't understood your post correctly.
I assume you are saying you can't find the recorded rbl files when using a external program. It might be you are looking at the program files folder when Vista has meant it has installed in your virtual store.
