Double Contrails
Started by Longhorn, August 23, 2008, 12:46:30 PM
Longhorn
Have seen this twice in last several days, double or more contrails.  Once with V1.6 and now V2.0.  Is this something new? or me.
AIR NAV RADAR BOX
BCD996XT
BCD396XT
ICOM IC-R2500
ICOM IC-R75
D130 - VHF/UHF ANTENNA-PREAMPED
75FT LONG WIRE-HF ANTENNA
Not sure what you are refering to in the pic, all seems fine to me.
Longhorn
Sorry..look above home and you will see two purple lines...
AIR NAV RADAR BOX
BCD996XT
BCD396XT
ICOM IC-R2500
ICOM IC-R75
Ok right, this is not something new its to do with aircraft which have a faulty GPS link to there transponder, this means there position suddenly jumps from one place to another (300miles +).
RadarBox plots it and you might see lines like that untill the aircraft goes out of reception.
Rumour around and I think there are some posts in this forum that some Learjet's do this delibarately to spoof there position so they can't be tracked well.
Longhorn
Thanks....for the info.  I back out of  Program and came back in, no more.
AIR NAV RADAR BOX
BCD996XT
BCD396XT
ICOM IC-R2500
ICOM IC-R75
Longhorn
Air Force GL5...Like you said "they do not like to tracked"
AIR NAV RADAR BOX
BCD996XT
BCD396XT
ICOM IC-R2500
ICOM IC-R75
Bethsalem
Faulty GPS or deliberate concealing of the aircraft's position?
