Jazeera Airways route request
Started by Storm, August 24, 2008, 01:42:19 AM
Storm
Any chance of adding J9 (Jazeera Airways) to the route finder function?
Storm
OK. No answer yet. Can I add the route manually then?
Not sure what you mean by adding it to the route finder function. If its in the online database which gets updated it will be shown otherwise you can add it manually.
Storm
What I mean is that the route is displayed for the Jazeera flights. Can you point me in the right direction as to how to add it to my database please?
Its very simple. Either use the DatabaseExplorer in RadarBox or any other external SQL Browser to open the routes database.
E.g File -> Database Explorer -> Choose routes table
Click add record and enter the details
FN = Flight Number
NO = Origin
ND = Destination
NV = Enter if you has a leg such e.g KJFK - EGLL - EHAM
CH = Enter date in sql time format (you should have other above that you can copy)
Make sure the airports are 4 letter codes.
Storm
Storm
AirNav, tried that and restarted RB the route did not show. Does the actual time matter? I mean the numbers no entering the actual field.
