New version: question about port 30003 / 7879
Started by Harry, August 25, 2008, 05:13:43 AM
Harry
Hello All,
Did anything changed on the output from port 30003 / 7879? My first results still shows only aircraft with a call sign all others aren't appearing on the port.
Harry
msteen
I have the same problems. A lot of flights do not show up in my file, so my flight watch is currently down :(
Storm
Harry
So it seems nothing has changed on this point. Maybe we can give support our wishes?  For instance I would like to see (like the SBS-1 does) a separated message for each new aircraft and a separated message when an aircraft sets it call sign.
Analyzing the xml output results in a lot of the same messages:
3B7781
081
CTM1040    2008-08-28   09:09   A-340-211   France   ET03.060   2008-08-28 09:09:09
3B7781
081
CTM1040    2008-08-28   09:08   A-340-211   France   ET03.060   2008-08-28 09:08:58
3B7781
081
CTM1040    2008-08-28   09:08   A-340-211   France   ET03.060   2008-08-28 09:08:48
3B7781
081
CTM1040    2008-08-28   09:08   A-340-211   France   ET03.060   2008-08-28 09:08:38
Harry
Nothing has changed unfournately except squawk has been added to the 7879 port. Request has been noted.
msteen
Anyone know where can I download RB 2008 so I can use that until the patch for 2009 is released ? I should really have the correct output on the ports for my projects.
Harry
Quote from: msteen on August 29, 2008, 12:42:52 PM
That version give the same output as the new version.
Harry
msteen
Quote from: Harry on August 29, 2008, 12:57:51 PM
Harry
I installed the old (1.5) version on an other computer now, and moved my own program there, and it all works again :) I've been in contact with Airnav support, and they sent the problem to the developers, and a patch will be made.
Harry
What is the problem with the new program in relation to your own program?
Harry
msteen
Quote from: Harry on August 29, 2008, 05:38:31 PM
Harry
Only aircraft which sends callsign in their messages are put out on port 30003, so I miss a lot of aircraft in this area (older fokkers and so on).
Example:
With 2009, this message got through:
ENKB,MSG,3,0,0,4784BC,0,2008/08/28,12:21:07.218,2008/08/28,12:26:07.218,CNO2306,01550,136,251,63.1044,7.7749,2368,,0,0,0,0
(SAS Boeing 737-600 with
But not a message like this:
ENKB,MSG,3,0,0,47806A,0,2008.08.29,18:33:51.794,2008.08.29,18:38:51.794,,04100,,,0,0,0,,0,0,0,0
(SAS Fokker 50)
Software version currently running: 2008.03.19 03:55
My program reads the messages, and post them to a mysql database.
I then process that data in various ways, as putting out info to be used on my phone, sends sms messages when interesting aircraft arrives and so on.
Harry
OK. I never did anything with the stuff coming from port 30003, only with the port 7879.
Yes, I'm also seeing this problem.  Aircraft without a callsign aren't output on port 30003.  This affects the addon sbsplotter, which uses port 30003 output.
