information displays
Started by jgrloit, September 01, 2008, 02:56:22 PM
jgrloit
In 2009 version, am I correct in thinking that if there is no aircraft registration then no information is displayed alongside the photograph location, even if flight information is available?
Could the information area laongside the photo's also show the country of registration, as a string, as I cannot remember all of the flags & country codes.
Is there any way for the system to show which flights, or aircraft are awaiting update information?
Rgds.
Based in Hexham - Tyne Valley
Request has been noted. There isn't a way to view details on items which are updating.
It should has within a second of an aircraft/flight appearing. Only on startup when you have lots of aircraft/flights proccessed where there is a delay.
