KLM Routes problem
Started by Storm, September 01, 2008, 03:11:59 PM
Storm
I started to notice KLM Route info problems. The routes are either reversed or not completed. I have only noticed this with KLM. However I also noticed a problem with a UAL out of Kuwait, ther route it shows is KIAD-KORD the origin OKBK is not there.
Can you check whether these routes were in the local database or downlaoded?
Storm
They were downloaded. Also I just noticed BAW125 the routing shown is OBBI-OTBD when it should be EGLL-OBBI-OTBD
I uninstalled and reinstalled the software but its still the same.
Storm
I changed the database but it always returns to the old incorrect data.
There is known fault with multilegged flights. This is being looked at.
Storm
ok but why does it change back when I edit it in the DB?
Storm
No DLH is affected too. DLH637 is reading OKBK-OEDF when it should be OKBK-EDDF
It overwrites the local database route as it does not match what is on the online database and hence it overwrites it.
