flight tracking alert feature
Started by merlinflyer, September 02, 2008, 05:35:48 PM
merlinflyer
i was trying to track a flight from madrid to heathrow IB 3166 and i put this into the alerts feature but i noticed that the flight showed up on screen as IBE 31GQ.
how can i track a flight when the last two numbers are changed to letters and why?
Often the flight number used on the aircraft is different to the published flight number.  For example, EZY764 is EZY50DZ.  I don't know why.
However, you can use wild cards (*) when setting up an alert, so maybe something like IBE31* might work.
When I'm looking to track a flight, say BAW009, I'll put all possible combinations into the alert box:
BA9
BA09
BA009
BAW9
BAW09
BAW009
Ok, so this is a bit of an extreme example, but I'm sure you get the idea.
merlinflyer
seems the only thing that does not change is the airline prefix
in the future i will use a combination of both replys
your  answers are very helpfull to me  as im still learning as i have only had this radarbox for 1 week.
thanks again for your replys
GlynH
Quote from: merlinflyer on September 02, 2008, 08:33:26 PM
Actually if you look in the example Allocator quoted above you will see the Airline prefix does change - BA-BAW
Why do they do that?
I had the same issue a few weeks ago when a friend of mine flew to Australia.
I input the flight details I had directly from the British Airways website and the airport monitors I believe and wondered why her flight was delayed.
Realised afterwards that BA should have been BAW...:-(
Didn't make the same mistake on her return flight - had a list like the British Airways 'Catch All' one referred to above but also added the Qantas & Singapore Airlines flight numbers...one heck of a list for one flight!
Kind regards,
-=Glyn=-
