Satellite imagery adrift
Started by Deadcalm, September 12, 2008, 04:34:55 PM
Deadcalm
I've just noticed that the satellite imagery has drifted out of synch with the coastline by a significant amount.  Is there a setting which I may have inadvertently changed, does anyone know?
DC
I think that you will find the satellite picture is correct and the coastline is just an approximation.  I know that tarbat uses the high definition outline produced by bones for the SBS-1.  I just switch off the Country Boundaries option when I'm using the satellite layer.
Allocator is right: if there is any inconsistency between the satellite photo and the boundary lines then the satellite photo is correct. We also switch off boundary lines when sat photos are being shown.
Deadcalm
Fair enough.  Didn't notice the discrepancy before.
DC
testmonkey
Quote from: Deadcalm on September 12, 2008, 09:06:54 PM
Try looking at Malta or other similar sized land masses. Doesn't even exist according to the boundary lines :)
testmonkey
Deadcalm
Can't seem to find the Country Boundaries option to switch off...  someone point me in the right direction, ta.
DC
Hi DC
Its in the Gereral Signs drop-down (next to the Home button).
Deadcalm
Airnav, and those interested.  I've been doing a little checking on the idea that the satellite map is more accurate than the outline.
Using a path profiler, I am finding that the satellite image is consistently wrong, and that the outline is more accurate, which is contrary to your assertion.
Simply by checking the same position on the path profiler against the identical point on both the outline and satellite image in RadarBox, the discrepancy is quite considerable in places.  (I am comparing points on the coast in the south of France - Sete, for instance).
In case I'm doing it wrong, try it for yourselves.  I'd be interested in any comments.  If I'm in error, I'll get me coat...
DC
DC,
Is this consistent, or is it at the edges of the layer?  It all looks OK to me at the centre when I'm watched aircraft take off and land.  Maybe it's an expansion thing?
Deadcalm
#9
Take at look at the attached pic.  Most of the coastline is out of synch.  I've not zoomed or done anything, and the map is a spherical projection.
DC
Deadcalm
Maybe you just answered the question yourself, DC.
Perhaps the satellite images are only accurate with Mercator projection? They seem more accurate for me with that. Perhaps they are pre-corrected for Mercator?
Deadcalm
Hmm... switching to the Mercator projection and reloading the satellite image certainly makes a difference.  Not perfect, but better.  I tend to use the spherical projection as a matter of course.
Maybe it would be an idea if Airnav were to add the proviso somewhere, that satellite imagery is only successful with the Mercator projection.
I won't be getting me coat on this occasion - just me hat!!
DC
