What Antenna Do I Need For A External Antenna , (More Info In Desc)
Started by Johnn, September 20, 2008, 06:05:50 PM
Johnn
I want to have a antenna outside , but is it true that the more Wire I use the less signal of something?
Also what antenna would be suitable to use for the box?
Johnn -
PEPITO
I am testing this equipment from LEPA in Majorca and things look very good.
Yes I suppose that more cable you use the more noise you will get.
I am using 20m of cable and things look prety good.
GP-1090 Antenna
1m low loss cable Ecoflex-10 with N connectors
Mast pre-amplifier AS-1090
20m low loss cable Ecoflex-10 with N connectors
AS-1090BT Bias-T for DC-Feed
1m Cable BNC/SMA
Got it from WIMO.com
Hi John, I'm not RB equipped yet and a newbie, but have been into radio for 50 years.   Every metre of co-ax reduces/degrades the signal somewhat - the better the quality (and bigger diameter) the less degradation.   There's several topics on the go in here, including this one
http://www.airnavsystems.com/forum/index.php?topic=1445.0
which address some of your queries.
