Mylog and Myflights
Started by mdobuk21, September 22, 2008, 07:55:26 PM
mdobuk21
Hi my name is Mark and i have just bought the rb, i was wondering if anyone knew why i can see the registration and code for all aircraft in the myflight tab, but when i go into mylog tab some of the aircraft have gaps where the reg should be? anyone have any ideas?
Mark
Mark,
When in MyLog, go to Tools, Populate and follow the prompts.
This will update those missing details if they exist.
mdobuk21
hi thanx for the quick reply! this may sound dumb but i cant find the tools menu!
Are you using the latest version of the RadarBox software - RadarBox 2009?
If not, then that's what you need:
http://www.airnavsystems.com/download/anrb/anrb20setup.exe
It installs in a completely new directory, so you don't need to uninstall if you have an earlier version.
mdobuk21
cheers for the help yeah its 2007!!
Tailwinds
Quote from: Allocator on September 22, 2008, 08:12:04 PM
As a fairly new user, I thought I would read some of the older posts and I came across the above comment. I don't have any problems as such but I wanted to check something out so just out of curiosity, I clicked "My Log", then clicked on "Tools" on the top menu bar but I certainly don't see an option to populate. I am using the 2009 version.
You should see this.  What options do you see?  Are you definately running the 2009 version - check in the Window heading.
Tailwinds
#7
tarbat...
thanks for your reply, I didn't realise that there was a "Tools" tab on the actual "My Log" page as it wasn't actually obvious to me at first. I was looking at the other Tools tab along the top.
