Feature request.
Started by reg, October 04, 2008, 05:19:07 PM
reg
Hi Airnav. As a new user i am enjoying and learning about all the features Radarbox has to offer. Kept me quiet for days.
Is it possible to enter in text form any location desired by the user and have it placed on the map/s. I did find this feature usefull with the sbs-1. Maybe this feature is allready available with Radarbox,  but have not yet found it,  even looking through the help section.
Regards. Reg
Looks like i got off on the wrong foot with no reply to my question. I do apologise to Airnav and members for naming the opposition's unit. Perhaps it was the wrong thing to do, but as a new member i am not sure what the policy is. Obviously from lack of members comments it looks like the feature asked for is not popular I will slide quietly into the background.
Reg
#1
Hi Reg
Don't worry - mentioning the opposition isn't taboo here - it's just that we've got a better thing to talk about! (apparently - personally I've never used the SBS-1.)
The answer to your perfectly reasonable question is, I'm afraid, no - you can't. I assume you know that you can display airport codes and names through the Map...Aviation Signs menu.
The nearest you can get to adding your own text is to create it as an outline - I've done that to add specific locations to the map. If you want to do this, look at the FAQ's and the Outlines thread.
Hope that helps!
Hi Reg,
Sorry looks like your post got lost a maze of other new posts when you posted. It isn't a taboo subject, don't worry :)
Unfourtanetly as Rod says you can do it unless you use outlines. We are looking to make the default globe more flexible to change and add details in the future.
RNAGG
This possible changes in maps is very good. In Brazil fix and airways isn´t actualized.
reg
 Rod, Airnav and RNAGG thank you for your replies. All understood from Airnav about missing my post. I am very impressed and  pleased that Airnav support have responded now. Rod i will try your suggestion and use the outlines feature.
Kind regards. Reg
Good luck outlining - Reg.
If you need more help, do ask - with any luck you'll get a faster response next time!
HMN851X
Hi only my second UTC is the same as GMT but in my Changed and Traked times box its showing UTC how do I change it to local?
Hi HMN851X, is that your car registration you're using as a handle - a Chrysler PT Cruiser perchance?
HMN851X
yes why did you ask? do you live on the Isle of Man?
Playing Big Brother, No, sw Cornwall!
Another feature request:
On the MyLog screen, below the photos is a big chunk of empty space. How about using that to display the route airports when you click a flight with a route - I personally don't carry in my head a decode for all the world's airports, and I doubt if I'm alone!
