BNC Connector
Started by mdobuk21, October 23, 2008, 05:56:58 PM
mdobuk21
Can anyone tell me if i can get a BNC connector for the back of my RB, so i can use my aerial that has a bnc connection, which is situated in my loft.
Mark
Terry
You can get a SMA to BNC adaptor from Maplins,£2-50.
                                Regards Terry.
#3
http://www.maplin.co.uk/module.aspx?moduleno=32015
Use of connector/adapter does increase the physical load on the socket and PCB connections
Quote from: CoastGuardJon on October 23, 2008, 09:04:23 PM
As long as you don't mistreat the connection, there isn't a problem - at least there isn't with my RadarBox 16 months on :-)
The connetors are small and not heavy so any affect is minimal.
I agree but any flexing of the lead puts an increased physical load onto the connector/pcb joint, due to the increased leverage length, personally I'd rather use a patch lead.
John Fairfax
As a newbie I have been following the discussion about BNC to SMA adaptors.  Today I went to my local Maplin store to buy a suitable adaptor, the only item they stock in this range - Part No: RS85G -  is not suitable as the SMA part of the item is reversed in that the centre contact is a socket not a pin the outer contact is a nut which is the correct configuration.
I can't find a supplier in this country.  Any suggestion please.
abrad41
Hello mate,
I am a newbie too, of about a month or so now. I got my adapter from http://www.rocketradio.co.uk/sma-male-plug-to-bnc-female-jack-interseries-adaptor-945-p.asp when I bought my Radarbox
Andy
John Fairfax
Thanks Andy,  Letchworth is not too far from here, I'll take a run up there next week.
John
#10
Quote from: John Fairfax on October 25, 2008, 09:55:58 AM
I'm surprised, as the description is correct.  Also, only the male part of an SMA connector has the "nut" on it, the female part is just threaded - as on the back of the RadarBox hardware. Also, the Maplin FAQ says:
Q) Is this type of connector suitable for a Icom IC-R5 scanner   - K Taylor
A) Yes it is.
And my adaptor fits my Icom scanner and my Yaesu handheld with SMA connectors too!
Are you sure that you were looking at the right end :-)
The link below goes to the Maplin RS85G part.
Below: This is what a BNC male to SMA male plug would look like - this definitely wouldn't fit.
Product Information
HERE IS A FEMALE SMA TO BNC ADAPTER
FOR RADIOS WITH FEMALE SMA CONNECTORS
SUCH AS QUANSHENG.JINGTONG,LINTON,
PUXING,WEIERWEI AND ANY OTHE RADIO
THAT USES A FEMALE SMA CONNECTOR
mdobuk21
cheers to all the replies!! the part arrived this morning!! aerial in the loft not as powerful as the supplied aerial!!
mark
John Fairfax
A) Yes it is.
[/quote]
Thanks for your reply.  I agree that the desription is correct but the units I looked at in the Maplin store definitley had a reversed centre contact on the SMA end.  I looked at the 4 items they had in stock and they were all the same.
Cheers, John
Royston525
Yep, try maplins and look for a SMA to BNC adapter there about 2.50.
Quote from: mdobuk21 on October 23, 2008, 05:56:58 PM
Mark
