Author Topic: Airnav Radarbox 2009 not maximizing  (Read 10074 times)
viking9
    • Aircraft Photography
« on: October 30, 2008, 10:12:03 PM »
I'm running Radarbox 2009 under Vista Home Premium SP1. When I run any other programs RB often refuses to maximize when I click on it on the taskbar. At other times the window will appear on th desktop but will not maximize for a period of 30 seconds or so. Anyone had the same problem?
Bury St Edmunds, Suffolk UK
15 miles SE of EGUN
http://www.viking9.co.uk
Deadcalm
Re: Airnav Radarbox 2009 not maximizing
« Reply #1 on: October 31, 2008, 07:42:46 PM »
There are quite a few posts on this - I'm running on XP and constantly have this problem.  I was under the impression that a new build was on the way, but haven't heard fom Airnav Support for some time, having struck up a dialogue...
DC
CZUL
« Reply #2 on: November 22, 2008, 02:05:49 AM »
I'm dealing with this ona daily basis. I also though the new software would have changed it but I'm always having to restart the software. Vista Ultimate, SP1 4GB RAM Core2Duo.
Blackthorn
« Reply #3 on: November 22, 2008, 06:47:10 AM »
Hi Tom
I have the same issue and it never remembers window position or size on exiting  using Vista SP1.
Kevin
« Reply #4 on: November 22, 2008, 08:51:44 AM »
I've never had this problem with RB 2009, but it did happen with the previous version, so this has been fixed for me.
I don't know why you are still having problems.
viking9
« Reply #5 on: November 22, 2008, 07:44:50 PM »
On my Vista PC I am now getting two copies of the map on startup. If I close down one the other closes too.  :-(
15 miles SE of EGUN
Blackthorn
« Reply #6 on: November 22, 2008, 08:07:19 PM »
Hi Tom
Are you running the program as an administrator? Perhaps its time for a re-install?
Kevin
viking9
« Reply #7 on: November 23, 2008, 11:42:05 AM »
Hi Tom
Kevin
Kevin,
Yes, I'm running as an administrator. If you remember, I've just completely re-installed Vista and all progs due to a Windows update screw up.
I noticed this morning that the second map didn't have the polar diagram. It's no great problem, just a bit of a nuisance.
Heavy snow here so no visit to Mildenhall today for me, though they are flying.
15 miles SE of EGUN
abrad41
« Reply #8 on: November 23, 2008, 12:01:39 PM »
I wish I could say the same, I have to be at work at 14.00 @ Mildenhall Base and I have to get there from Dereham.
Andy
Blackthorn
« Reply #9 on: November 23, 2008, 12:16:07 PM »
We had some snow here as well but sunny now.
Not sure what to suggest about your map issue.
« Reply #10 on: November 23, 2008, 01:22:47 PM »
Hi Tom
Kevin
Kevin,
Try this:
- Run RB, you say that 2 maps are opening here
- Right click on each map in turn and select Close Map
- Goto Map > Open/Save > Open Map and select Default
- Maximise that map if you wish so it fills the whole map area in the RB interface
- Position the map as you like - home in the centre?
- Goto Window > Record Desktop
- Shut down RB
- Run RB again and see what happens.
viking9
« Reply #11 on: November 23, 2008, 02:31:30 PM »
Try this:
- Shut down RB
That's cured it.
Thanks Allocator.
15 miles SE of EGUN
viking9
« Reply #12 on: November 23, 2008, 02:34:17 PM »
Andy
Hi Andy,
I hope you had a safe journey to work.
I've just been out in the car and it's all melting away.
15 miles SE of EGUN
Blackthorn
« Reply #13 on: November 23, 2008, 05:00:50 PM »
Whilst on the subject of maximising
If I size my Airnav program window to fit part of my vista desktop then exit the program correctly, why does it not remember the windows sizing?
When I start the program up I just end up with a very small window which I have to reposition again.
« Reply #14 on: November 23, 2008, 05:25:30 PM »
A very long-standing and very annoying bug from at least February - see http://www.airnavsystems.com/forum/index.php?topic=448.msg3236#msg3236
Airnav, any chance of fixing this very old bug in v2.1?
