Help! Can't send reports
Started by prbflight, August 07, 2007, 04:34:26 PM
prbflight
Hi All,
I can't send any reports.  I keep getting the following message
'Could not connect to SMTP server to send auto-report'
I am running Norton Internet Security 2007.  I have turned off my firewalls (at least I think I did) and still no luck.
What should I try next?  Do you think I am missing something?  Any ideas would be appreciated.
Can anyone help?
Paul
Temporarily turn of Norton and restart RadarBox 2007 and try.
prbflight
Quote from: AirNav Support on August 07, 2007, 04:59:31 PM
Tried with no luck.  I'm running Win XP with all service packs and I use Outlook as my e-mail client.  Any other suggestions?
Paul
prbflight
Could it have something to do with my US Robotics Broadband router?
Paul
Your router should not affect the sending. I guess you have tried sending to different emails addresses.
Did you get Mikes earlier log report?
DaveG
Only if it has a hardware firewall and it is blocking the ports used by RB ?  But you can test this by turning the Hardware Firewall off or moving your PC onto the DMZ part of the router.
If all that is &£$&*$ post your model number.
Cornwall, UK
That is true, however most home firewall routers don't have too much issue sending things out its more receiving.
prbflight
Quote from: AirNav Support on August 07, 2007, 07:39:08 PM
Did you get Mike's earlier log report?
Yes I did get Mike's log report.  I will try sending my report to another address.  Until now I have only tried to send to myself.
Roadrunner
My PC is connected via a Broadband router (Netgear Range Max 240) I use Virgin+ PC Guard and as I said earlier, have had no problems with emails. However, I did have a problem initially trying to set up reports from SBSpopulate to Mode_S group ay Yahoo due to the IP address or something. Don't know if their is a clue there?
prbflight
Quote from: prbflight on August 07, 2007, 08:01:19 PM
No luck using a different e-mail address.
Paul
prbflight
Quote from: Roadrunner on August 07, 2007, 08:04:33 PM
That could be a clue for sure.  I have never been able to send log reports to a group using Acarsd.  As well, I have never been successful in setting up a server using a no.ip address for Acarsd also.
Paul
DaveG
Paul what ISP are you with ? and do you know if your going through an ISP Proxy ?
Cornwall, UK
prbflight
Quote from: DaveG on August 07, 2007, 08:22:10 PM
I am with Vianet and as far as I know I do not use an ISP proxy.  Never had to worry about that whenever I set up an internet connection or e-mail account.  My knowledge is limited in this area.
Paul
CanadaKen
prb....by any chance are you running anything like Spyware Doctor?
CK
Monitoring on Canada's "Left" coast
prbflight
Quote from: CanadaKen on August 07, 2007, 09:20:22 PM
CK
No.  My Norton Internet Security 2007 has spyware detection but I've turned it off and still no luck.
Paul
