No ADS-B blues...
Started by oceans777, November 02, 2008, 08:38:13 PM
oceans777
I can now strongly recommend NOT disconnecting the BNC-male connector on your new expesnive, low-loss coaxial cable from the pre-amp bias-t/RB, then forgetting it's on the floor and accidentally crushing the connector and the end of the coax in a metal door hinge.
It does absolutely nothing to improve your coverage area.
This is KLAX monitoring, off air for a day or so for repairs.
Sounds like a unfortunate accident, hope your back online soon.
I see you're back, John. Well done!
Is your range better now?
oceans777
Hi Rod,
Yes back at last. I went from 60 feet of LMR-400 cable to 45 feet so no great increase in range that I can tell.
But it is WAY better than the crushed BNC and cable, tests prove :-)
